Old 09-14-2019, 07:51 PM
ZiggyL78's Avatar
ZiggyL78 ZiggyL78 is offline
Default L78 Nova fan noise.
I have a 70 Nova L78 that is all stock and sounds normal. I have had a number of L78 Novas and a few of of them had quite a loud howl that sounded like a truck. I didn't think there was anything wrong and never really searched to see where it comes from. This car I have now has what looks to me to be a stock shroud and 5 blade fan with no thermal clutch. It runs great and I sort of miss that howl. I have never heard the same sound from any other Camaro or Chevelle with a L78.
Real Canadian Rock
https://www.youtube.com/watch?v=Zdeo-i6uw5g
Attachments - The Supercar Registry 100_3247_opt.jpg 100_3246_opt.jpg 100_3240_opt.jpg
Old 09-14-2019, 08:26 PM
WILMASBOYL78's Avatar
Post 5 Blade Nova BB Fan...
The 'howl' as you call it is standard equipment for these fans...they all do it.
Back in the day the noise was the reason a lot guys went with a flex-a-lite unit...the noise got to them.
No need to worry...if folks ask about the noise, just tell them you have a mini-blower installed and don't open the hood
-wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 09-15-2019, 03:10 AM
ZiggyL78's Avatar
-wilma
Thanks.The problem is mine doesn't do it.Do all L78s use a 5 blade fan?
Real Canadian Rock
Old 09-15-2019, 03:35 AM
rts rts is offline
Default Fan noise
Tom
Why do L-78 novas have the fixed blade only and all other L-78 models have fan clutches???
Thanks in advance
Mike
Old 09-15-2019, 10:53 AM
Because there's no room for it between the water pump and the radiator,like other vehicles that used a fan clutch.
The 7 bladed fans use the clutch and it needs more space.
Old 09-15-2019, 12:45 PM
Originally Posted by rts View Post
Tom
Thanks in advance
Mike
As noted, the space is the issue...the first year of the big block Nova [1968] used the short water pump with a clutch and 5 blade fan...that was the only year for that setup.
And despite what the 'repop catalog' guys show on their websites, there was never a spacer between the fan and water pump on the 69-70 cars. As for the lack of noise...?? hard to answer that one...maybe post a photo of the fan blade so we can see what you got.
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
The Following User Says Thank You to WILMASBOYL78 For This Useful Post:
Arrowsmith (09-15-2019)
Old 09-15-2019, 03:01 PM
Igosplut's Avatar
Igosplut Igosplut is offline
There are several GM versions of those 5 blade heavy metal non-flex fans. Some have more of an aggressive pitch than others, that were installed on 70-72 small and big block trucks. Someone might have put one of those on, trying to pass it off as the correct fan (you have to look close at them).
WOT
Old 09-17-2019, 01:32 AM
ZiggyL78's Avatar
Here are some pics.Hard to really get good ones.
https://www.kijiji.ca/v-view-details...dId=1460372449
Real Canadian Rock
Old 09-17-2019, 02:00 AM
68 Chevy II 68 Chevy II is offline
Looks like a painted flex fan.
The blades don't look correct at all
Just my 2 cents
Tony
Old 09-17-2019, 02:36 AM
fan not correct in my opinion.
