Old 10-03-2019, 06:22 PM
JoeC JoeC is offline
my old Hurst catalog lists the 1969 Nova shifter with console 391 7875
1969 Nova with console shifter 391 7879 is the replacement that comes with just shifter body and without the stick
the stick they list is the 4106
some people like to change the stick out for the 7236 or the 7436
Old 10-06-2019, 11:51 PM
ZiggyL78's Avatar
ZiggyL78 ZiggyL78 is offline
Originally Posted by YENKO DEUCE REGISTRY View Post
The shifter listed in the catalog's won't work, if you have a '69 with a console you need this one - not listed in any catalog. I got mine from Jody Haag of Jody's Transmissions, fits perfect.
Were those seat belt holders an option for the Nova?
Thanks
Real Canadian Rock
https://www.youtube.com/watch?v=Zdeo-i6uw5g
Old 10-07-2019, 10:29 AM
Nova Pete's Avatar
Nova Pete Nova Pete is offline
Hi
Thanks for that! I did read some posts from years ago that you had talked about your 69 SS shifter search.
I also talked with crash about the shifters.
Thanks!
Pete
Old 10-07-2019, 10:36 AM
Nova Pete's Avatar
Thanks
Mine have those also. But not sure on the option. Maybe it was part of the SS package.
Old 10-08-2019, 05:42 AM
Kurt S Kurt S is offline
What's the difference between that 391 7879 shifter and a 69 Camaro shifter?
Kurt S - CRG
Old 10-08-2019, 01:12 PM
WILMASBOYL78's Avatar
Post Nova SS package...
The exterior and interior trim options including seats, consoles, gauges, colors, moldings, etc. had no connection to the SS Package. The only items that were unique, beyond the driveline, were the hood louvers, SS emblems and blackout front grill and headlite bezels.
-wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
The Following User Says Thank You to WILMASBOYL78 For This Useful Post:
Nova Pete (10-08-2019)
  #17
Old 10-08-2019, 03:30 PM
the 69-72 Nova (with console 7879 and 7875) and 68-72 Chevelle Hurst Shifter body has an offset design using a 90 degree angle. (same design but used a different offset )
the 67 to 69 Camaro shifter body has an offset design using more like a 45 degree angle
The 68-72 Nova is confusing because Hurst used a different shifter for console and non console , used the Camaro shifter for 68 Nova with console only, and used at least 4 different installation kits
the picture shows a 67-69 Camaro Hurst shifter body on the left and the 68-72 Chevelle on the right
Old 10-08-2019, 06:34 PM
YENKO DEUCE REGISTRY's Avatar
I believe they were standard with the bucket seat option. If you wanted bucket seats in a Nova it also required the deluxe interior option which upgraded things like the door panels, carpeting, bright trim on the dome light, day/night mirror, cig liter, glove box light, dome switch in the pass door jamb, etc...along with those seat belt holders, but I think the other two buckles go into some plastic clips that go on the bucket seat bases - not sure if these plastic ones were factory though, might have been an accessory.
Marlin
The Following User Says Thank You to YENKO DEUCE REGISTRY For This Useful Post:
Nova Pete (10-09-2019)
  #19
Old 10-08-2019, 07:56 PM
Thanks Joe.
That confirms what I was thinking I saw - slightly different designs, but pretty much the same effect of moving the handle over 2-3 inches. They might not be in the same spot, but look really close.
Kurt S - CRG
Old 10-09-2019, 10:21 AM
Nova Pete's Avatar
I ended up buying the whole shifter kit, brand new from Shifterdoc.
I should have it soon. Then im going to remove the transmission and take it apart over the winter. Then I will install the new shifter. Fun times ahead.
