Old 10-24-2019, 07:06 PM
Use the Manley (stock type) Rockers cause they will not go bad and change the rear gear. No matter what cam a 302 Chevy runs it needs a stiffer gear or change the trans gears to have a lower first gear for easy light to light driving. Re do the distributor curve and have Eric tune/go over your carb. Then go have fun.
The Following User Says Thank You to Salvatore For This Useful Post:
NorCam (11-08-2019)
  #22
Old 10-24-2019, 08:33 PM
napa68 napa68 is offline
Originally Posted by norcam View Post
here is tim's garden tractor come next summer...
lmao
Jims69z28 (10-25-2019)
  #23
Old 10-26-2019, 03:41 AM
COPO COPO is offline
With the M-20 trans and the 3.73 rear gear, you're already equivalent to an M-21 or M-22 with a 4.27 rear gear. Running a 4.56 rear with the M-20 would be equivalent to a 5.22 rear with a close ratio trans. First gear would be a screamer.
The Following 3 Users Say Thank You to COPO For This Useful Post:
GaryC (11-12-2019), NorCam (11-08-2019), YENKO DEUCE REGISTRY (10-28-2019)
  #24
Old 10-27-2019, 02:40 AM
Love my M20 with the 4.56 gear in my Z.
GaryC (11-12-2019)
  #25
Old 10-30-2019, 10:44 PM
aaronkl84corvett aaronkl84corvett is offline
I wound up ordering a custom ground Bullit cam -
can't wait to install it - I have a set of roller tip comp 1.52 rockers, heads already have screw in studs and guide plates - and I will be installing stiffer springs to compensate -
the cam is thus!
CHS 278/282-F12+5
Duration @ .050 = 248/252
Lift with 1.5 rocker = .530/.540
Valve lash (hot) = .016/.016
Lobe separation = 112
Intake centerline = 107
so kinda like a tight lobe LT1 with much more aggressive ramps.
I'll be running a set of 1 3/4 Kustom clone Z28 Headers -
I ordered a Flowmaster American Thunder exhaust setup = but I won't be running he Super 44 mufflers, but rather (either) the Dynomax Ultraflow SS or a Set of Borla XR-1 mufflers -
I like this system because the tail pipes (while larger at 2.5") exit in the stock location with a 45" cut like the original tailpipes.
keeping the m20, and 3.73s
Also will be installing a set of BFGoodrich or Coker WideOval Radials on a set of vintage Minilite wheels -
CAN NOT WAIT!!!
The Following 3 Users Say Thank You to aaronkl84corvett For This Useful Post:
markinnaples (10-30-2019), napa68 (11-08-2019), NorCam (10-31-2019)
  #26
Old 10-30-2019, 11:59 PM
L_e_e's Avatar
L_e_e L_e_e is offline
I have the Borla XR-1's on one of mine, a little loud but I like it.
Sorry for the crappy cell phone vid.
The Following User Says Thank You to L_e_e For This Useful Post:
napa68 (11-08-2019)
  #27
Old 11-06-2019, 05:36 PM
Sounds like a good combo Aaron. Keep us in the loop.
Old 11-06-2019, 05:42 PM
I am sure you have already considered this, but if you wanting more aggressive than an LT-1 camshaft, using "stiffer springs" you are risking lobe failure. You can combat to some extent by using edm lifters, and making sure you use a good high zinc oil.
Still, if I were going stiffer than stock springs, I think I would just go with a roller cam package. Just my .02 cents. Wish you luck either way.
Old 11-07-2019, 01:31 AM
Yes I have - and actually - almost had a catostrophic failure with the LT1 cam due to TOO MUCH ZDDP.
I had foolishly assumed that if one bottle of ZDDP+ was good, then a bottle and a 1/2 would be better insurance -
BOY was I wrong - after 800 miles, the lifters had spalling - but not obvious damage to the cam lobes and it mic-ed out correctly
I do however have more spring pressure than the stock Z28 springs - but not 130-140lbs like the current solid flat tappets want
Old 11-07-2019, 02:06 PM
Do you get a highway drone in the car?
I am either ordering the XR1 or Dynomax Welded Ultraflows
