Old 04-18-2020, 05:51 PM
Steve Shauger's Avatar
Administrator
Default The Ultimate 68 Camaro Restoration Guide
Chick (68 Camaro Z28) with the assistance of Bob Cardillo produced the most detailed and comprehensive restoration document I've ever seen. This is a step by step picture documented restoration, which solves myths, and leave no stone unturned. A big thank you for providing this, and sharing with our members! The stunning finished product... Index is located in the following post.
www.yenko.net
www.vintagecertification.com
The Following 13 Users Say Thank You to Steve Shauger For This Useful Post:
67 Nova Boy (04-18-2020), 68camaroz28 (05-01-2020), bergy (04-18-2020), BillD (03-20-2023), camarocards (04-18-2020), dykstra (07-12-2021), HawkX66 (04-18-2020), L78 Fred (03-21-2021), mhm1966 (11-08-2021), napa68 (11-27-2022), SS427 (04-19-2020), X66 714 (02-05-2023), ZLP955 (04-19-2020)
Old 04-18-2020, 05:59 PM
Administrator
Default Index A
Alphabetical Index A
Chick’sTeam Camaro Build Thread - Time for Another 68 Z/28 to be Restored
Tableof Contents
68Z-1970 Pictureof Eddie Meadows (orig. owner) – Post32
68Z-1983Purchase - what I brought home in pieces - Post1244
68Z-2010 Howit looked from lacquer paint job in mid-80’s - Post1
68Z-2016 Sawsome sunlight for 1st time since 1979 – Post1263
68Z-2017 Reunitedwith original owner Eddie Meadows – Post1317
68Z-2017 Picturetaking for Hemmings Muscle Machines – Post1348
A-Armassembly painted - Post272
A-Arm rubberflap shields-drilling NOS inner fenders – Post1045
A-Arm rubberflap shields making staples – Post1045
A-Arm rubbermaterial with cords – Post971
A-Arm shims- Post 674
A-Arm upperrubber bumper #384220 -Post 214
Air cleanerconnector #3923260 to valve cover -Post 592
Air cowlplenum air filter A226CW original vs. later -Post 236 &241
Air cowlplenum air filter cheap replacement – Post1191
Air cowl plenumcarb stud – Post 1013
Air cowl plenuminstalled – Post 1191
Air cowl plenumoriginal installation – Post1011
Air cowl plenumoriginal seal – Post1013
Alternator -after restoration original dated 7H10 -Post 148
Alternator -before restoration original dated 7H10 – Post46
Alternatorbrackets - comparing original GT stamp to reproduction stamp -Post 160
Alternatorbracket to header and alternator installation - Post795
Alternatorbracket alignment front vs. rear on alternator -Post 800
Alternatorbracket alignment rear of alternator vintage picture -Post 804 & 806
Alternatorwiring boot original - Post344
Aluminumrestoration, intake and distributor – Post128
Assembly ofcar - rear in subframe in front -Post 454
Assembly ofcowl (Firewall) and under dash list – Post839
Assembly offenders and front end - 1069& 1073
Astroventilation parts and info -764
www.yenko.net
67 Nova Boy (02-05-2023)
Old 04-18-2020, 06:09 PM
AnthonyS's Avatar
AnthonyS AnthonyS is offline
Yay!
Old 04-18-2020, 06:13 PM
Administrator
Default Index B
B
Ball jointsriveted - Post160
Batterycable negative clips #3857706 -Post 609 & 612
Batterycable negative clips #3857706 located on frame -Post 621
Batterycable negative clips - how to install -Post 682 & 687
Batteryground for Y55 - location and hardware – Post1191
Battery holddown clamp bolt - original with 0.87 inch diameter washer - Post1293
Battery holddown clamp NOS correct piece – Post860
Battery holddown clamp original vs. Service replacement-Post 366 & Post490
Battery holddown clamp original dip painted and stampings – Post1293
Battery holddown clamp painted original survivors (3) - Post511
Battery holddown clamp restored and bolt – Post1183
Battery tray– Post 1273, 1275,1276, 1280,1281, 1283& 1287
Battery traycontinued – Post 1291& 1292
Battery traycontinued - how to make tab correct - Post1304
Battery Y55NOS purchased 1983 (no Energizer script) – Post1183
Battery Y55NOS early 70’s vintage with Energizer script- Post1261
Battery Y55 -How to gut – Post1394 & 1396
Bezels - Sidemarker lights painting grooves black – Post959
Body and componentsmedia blasted to bare metal – Post8, 9 &10
Body rubberflap in rear quarter housings - originals -Post 196
Body work –Post 53, 59,61, 65,69 & 98
Body workcontinued – Post 106& 113
Brakebooster hose bracket-original vs. reproduction -Post 269
Brakebooster restored and hardware - Post155
Brakebooster valve comparisons original to later types – Post814
Brake boostervalve comparisons original to newer reproduction found – Post1306 & 1309
Brakebooster valve and seal #546180 both original -Post 607
Brakebooster valve and seal with original clamp installed – Post902
Brake clutchpedal assembly restoration -Post 410
Brake druminternal components and stamping -Post 258
Brake drumpaint for components - close match -Post 262
Brake drumshoes and assembly -Post 486
Brakeemergency cables with hardware installed – Post1409
Brake hoserubber U-shaped clips - original to reproduction -Post 182 & Post259
Brake hoserear original - Post280 & 302
Brake lineand hardware installed pictures – Post1176
Brake lineclips and hardware (note - ignore bluing for ’68) -Post 524
Brake lineclips and hardware by part number in AIM -Post 541, 543& 545
Brake lineclips and hardware by part number in AIM -Post 587
Brake linerear bracket original vs. reproduction - Post416
Brake linerear bracket with bolt attached to 12 bolt - Post448
Brake mastercylinder (found out later a re-stamp) – Post129 & 796
Brake mastercylinder and booster NOS 5/31/68 – Post851
Brake mastercylinder WT original vs. re-stamp – Post1362
Brake mastercylinder WT original rebuilt and valve with distribution block – Post1365
Brake systemdirectional block and valve restoration – Post852
Brake systemvalve nut re-face (Note valve nut should be phosphate for ‘68, clear zinc for’69) – Post 856
Bucket seatrail for seat in and out - Post304
Bumper frontinstallation – Post1161
Bumperguards NOS – Post 114
Bumper rearNOS guards and installation – Post1151
Bumper rearlicense plate light Bracket installation and light differences – Post1146
www.yenko.net
Old 04-18-2020, 06:14 PM
Administrator
Default Index C
C
Car Show:11/2016 MCACN - Celebrity Pick Award winner – Post1267
Car Show:12/2016 East Coast Indoor Nationals December 2016 - Two awards – Post1272
Car Show:06/2017 Camaro Nationals, Gold – Post1317
Car Show:06/2017 Camaro Nationals judging demerits – Post1329 & 1330
Car Show:06/2017 Camaro Nationals judging demerits – Post1349
Car Show:06/2017 Camaro Nationals judging demerits – Post1355 & 1360
Car Show:11/2018 MCACN 999/1000 and Platinum Pick best stock Chevrolet – Post1382
Car Show:06/2019 AACA Senior award – Post1398
Carb dated7A1 List 4053 – Post 68
Carbmanifold stud – Post1087, Post 1111& 1119
Carbmanifold stud information (Stan NCRS judge) – Post1189
Carb studoriginal ‘68Z - Post592 & 1011
Car cover(have 4 of these) no longer available – Post1157
Chromedoriginal items - Post757
Clutchbellcrank lower push rod -Post 791
Clutch fork#3892632 and spring - Post590
Clutch forkhardware and GM number list -Post 683
Clutch forkspring and rod attachment issue with headers – Post823
Clutch forkspring and rod attachment issue with headers fixed – Post960
Coil springtag Skip’s ‘68Z survivor -Post 540
Consolegages original - Post279
Consolerestoration pictures + (part numbers) and installed – Post1138
Consolespecial nuts #3792287 -Post 691
Cowlinsulation under dash pad (NOS) - purchased 1979 - Post414 & 419
Cowlinsulation under dash pad (NOS) - purchased 1979 restored -Post 449
Cowl insulationunder dash pad rubber plugs original #3868790 -Post 595
Cowl paintedblack - before paintPost 140 & afterpaint - Post150
Cowl paintedbutternut yellow blend in -Post 243
Cowl panelseal #3927464 – Post963
Cowl panel -Z28 stripe dimensions – original - Post3 & 963
Cowl pictureshowing locations clips, lines, speedo, oil, grounds, etc. - Post 719
Cowl reversebackup light wiring to cowl connector -Post 726
Cowl seal#3927464 – Post 62
Cowlstampings PTB Post 692& 698 (green)
www.yenko.net
Old 04-18-2020, 06:15 PM
Administrator
Default Index D
D
Dash heaterand defroster control panel restoration original -Post 775
Dash installed– Post 1111
Dealershipscript, Roger Dean added to car – Post 1265
Dimmerswitch grommet original -Post 745
Disc brakecaliper original 4 piston -Post 163 & paintedPost 404
Disc brakedistribution block and pressure regulation valve -Post 186
Disc brakehose bracket - Post160
Disc brakehoses (NOS) - stenciled - Post351
Disc brakemounting plate original re-plated -Post 249
Disc brakeshoe kit #5470879 - Post429
Disc brakepressure regulation valve ‘68 to ’69 – Post877 & 880
Distributorcap D308/D308R - Post594
Distributororiginal #1111266 dated 7A25 - Post52 & 664
Distributorvacuum lines - Post581
Door armrest pads, original vs. PUI – Post1080
Door glasshardware – Post1053
Door handlegaskets (NOS) #1154551 -Post 377
Door handleoriginal thickness vs. other years -Post 326
Door handlere-chromed and #9709600 push button -Post 374
Door handleready for installation -Post 700
Door hingearea painted – Post 20
Door hingebolts (3 different manufacturers) - Post20
Door keylock and gaskets - Post809
Door keylock original vs. Service replacements - Post1379
Door latchoriginals and door latch rod covers - Post508 & 1053
Door latchespainted – Post 1068
Door lightswitches - original -Post 700
Door lock originalpush knob – Post365
Door mirrortaking glass out for re-chrome -Post 585
Door mirrororiginal date code 10-DMI-7 - Post43
Door mirrororiginal restored and installed – Post1161
Door rubberbumpers - original -Post 700
Door rubberbumpers (NOS) #4721222 – Post1094
Door sillplates (NOS) with rivets purchased 1979 -Post 810
Doorweather-stripping (NOS) – Post1134
Door windowcranks - Post 540& 567
Door windowcranks assembly after re-chrome – Post881
Door windowfuzzies - https://www.camaros.net/forums/3414713-post1077.html]Post 1077[/url]
Drag linkoriginal blued - Post208
Driveshaftpaint markings after Evaporust bath -Post 271
Driveshaftpaint markings installed – Post1409
Driveshaftyoke - paint markings -Post 285 & restoredPost 426
Driveshaftrestored - Post322
Drum brakehardware - Post 393& 395
Drum brakewheel cylinders rear -Post 276
www.yenko.net
Old 04-18-2020, 06:16 PM
Administrator
Default Index E&F
E-F
Emblems -fender (NOS) 302, bezel and Camaro – Post959
Emblems -fender original 302 emblems Eddie had taken off car late 60’s – Post1317
Emblems - trunklid Fisher #7752901 - Post1361
Emergencybrake cables - Post401 & hardware413
Emissionssticker radiator support – Post1187, 1188,Post 1238
Engineassembly #3830711 head gaskets, pistons, heads, etc. -Post 506
Engine cam,Crane blueprint specification – Post1130
Enginecompartment original ‘68Z (cook_dw) with air cowl plenum - Post1004
Engine dressup starting - Post 582& 608
Engine dynosheet - Post 531
Engine headbolts original - Post481
Engine mount#6258154 (not correct purchased 1979) -Post 484
Engine mountcorrect - Post 500& Post 505
Engine mounthardware original vs. reproduction - Post482 & 539
Engine oil pandrain hole “TR” bolt - Post43
Enginepainting at plant picture -Post 646
Enginepiston original - Post412
Enginestamping pictures -Post 168
Engine withtransmission going in subframe -Post 735 & 736
ExhaustGardner installation – Post1168
Exhaust pipehanger rear originals - Post554
Fan shrouds,original vs. (NOS) Service replacement – Post1087
Fender sidemarker bezel differences – Post70 & 71
Flashersignal Stat 175 - Post783 & 785
Fuel pumpAC40524 used on ‘68 Z/28’s – Post1260
Fuel pumporiginal bolts - Post201
Fuel pumpplate, black or bare metal – Post872
Fuses colorcoded – Post 1294
www.yenko.net
Old 04-18-2020, 06:17 PM
Administrator
Default Index G
G
Gas caplocking (NOS) #986970 – Post62
Gas caporiginals riveted handle -Post 373
Gas caporiginals riveted handle look added to NOS cap -Post 546
Gas pedal#3920296 review - Post365
Gas lineclip #3881339 clip with screw #3886522 & #3841230 -Post 586
Gas lineclip #3881339 install how to -Post 608
Gas tankanti-rattle strips – originals -Post 269 &1143
Gas tankfiller neck cover and phosphate screw – Post1014
Gas tankfiller neck hose and hardware - Post298 & 300
Gas tankfiller neck hose hardware clamps original - Post302
Gas tank fillerneck installation - Post1014
Gas tank installed– Post 1143
Gas tanksending unit original vs. #19179532 Service replacement -Post 520
Gas tankstrap - original semi-gloss black -Post 251
Gas tankstrap and bolts with nuts -Post 268
Gas tankstrap original bolt vs. reproduction -Post 275 & Post425
Glassquarter windows and trim – Post1053
Glasswindshield with rear glass and trim – Post1127 & 1128
Glove boxdoor Camaro script removal and parts – Post905
Grille endbracket installation with rivet – Post1144
Grilleinstallation – Post1117 & 1152
Grillematched for original look gray and painted – Post1144
Grille prepfor paint (NOS purchased 1983) - Post957
Ground atgauge cluster housing (speedo/tach) - Post1139
Ground strapscrews #9420415 - Post595
www.yenko.net
Old 04-18-2020, 06:18 PM
Administrator
Default Index H
H
Hardware#124829 Z-bar nut – Post1315
Hardware#272876 shackle nut phosphate – Post1301
Hardware#3831892 - Post427
Hardware #3873852beside #3747933 carb studs – Post1013
Hardware#3933052 10-24X1/2” AMK correct – Post945
Hardware#5959164 rear tail-light screws – Post980
Hardware#9418962 console screw – Post1043
Hardware#9420415 ground strap screws – Post595
Hardware#9780422 three different suppliers - Post748
Hardware andfastener list by part number - Post1253
Hardware-fender clips - Post302
Hardware spoiler– Post 1087 (Foundlater to be acorn nuts!)
Headergaskets made as GM originals -Post 508 &1301
Header GM hardware- https://www.camaros.net/forums/3940585-post1308.html]Post 1308[/url]& 1309
Headers-Kustomreproduction - Post263 & coated Post 279
Headlight bucketsoriginal restored – Post1119
Headlightelectrical connectors original -Post 309
Headlight T3date stamping original – Post39
Headlight T3testing - Post 884& installed Post1152
Headliner installed- Post 1080
Heater box andcore dated 67L - Post485
Heater hose –Post 995 &NCRS information Post1042
Heater hosewith GM logo picture taken Summer ‘68 (cook_dw) (Note: Heater hose for 68 used GM logo & by early 69 modelschanged to grooved) - Post1004
Hood bumpers- original vs. reproduction - Post1073
Hood hinge#3910668 comparison original to Service replacement -Post 269 &270
Hood hingeto fender screw differences – Post1254, 1255& 1256
Hood hinge andlatch restored - Post361
Hood hingehardware #9419301 - Post480
Hood latchparts - Post 256
Horn relayrestored - Post148
Hornsrestored by horn works - Post170
Horn screwsoriginal zinc - Post413
Hose clamporiginal - Post365
www.yenko.net
Old 04-18-2020, 06:19 PM
Administrator
Default Index I-K
I-K
Idler armoriginal #3917581 and seal #5693027 – before and after -Post 204
Ignitioncoil bracket original vs. Service replacement - Post413
Ignitioncoil comparison - Post492
Ignitionswitch - pick it when you have no key – Post1379
Innerfenders NOS - layout for A-Arm flaps - Post1020
Innerfenders NOS - drilling for stapling rubber shields & making staples – Post1045
Intakemanifold bolts shouldered and non-shouldered -Post 581
Intakeoriginal #3017610 restored - Post664
Intake oilfill tube cap - original vs. Service replacement -Post 369
Intakethermostat housing – Post37
Interiorbucket seat catch stops restored – Post1251 & 1261
Interiorcarpet installation front – Post735
Interiorcarpet original tag – Post4
Interiordoor panel fuzzies (NOS) vs. reproduction – Post1143
Interiordoor panel installation – Post1156 & 1157
Interiorlace vs. reproduction – Post1191
Interior(NOS) package tray #7666129 – Post1134
Interior pillarpost seals original – Post349
Interiorrear view mirror original restored – Post1140
Interiorsail panels re-glued and installed – Post1097
Interiorseat belts – original - Post1142
Interiorseat belts - original Model 137 vs. Model 177 – Post1183
Interiorseat rear - Al Knoch issues – Post1191
Interior seatrear - correct burlap and spring & view from trunk – Post1251
Interiorseat rear - correct original cover installed – Post1297
Interiorseat track hardware original restored – Post1191
Interiorsill plates (NOS) purchased 1979 with rivets – Post1191 & 1232
Interiorwindow - vent knob repair and put back on after chroming – Post1303
Judging BowTie results – Post1232 & 1238
Keys-Briggs& Stratton - Post304 & 1249
Kick panelsOER installed - Post709
www.yenko.net
