Old 04-25-2020, 06:42 PM
enio45 enio45 is offline
Default Reverse lockout rod
can anyone pls provide the measurement tip to tip for either a BB or SB lockout rod for 69 Camaro?
i have one gm rod but not sure of the application - no # stamped into this one.
thanks alot...
this is the long rod from trans reverse lever to the bell crank.
thanks alot for the info
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 04-25-2020, 08:24 PM
Steve Shauger's Avatar
Administrator
Eddie I have an unstamped SB and it's just over 20 .6 inches . On the outer edge of that inserts into reverse lever on trans and bell crank. Not installed but that's what I believe the application.
www.yenko.net
www.vintagecertification.com
Old 04-27-2020, 05:52 PM
Steve, thank you for checking.....mine tip to tip is 20 3/8
I believe it came off my Z - been a while,
how much longer would the BB rod be then. I know the shifter rods are not much different - around 1/2 to 5/8 if i recall.
are you sure yours is SB then?
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
