Old 04-28-2020, 12:43 AM
jbtech's Avatar
jbtech jbtech is offline
Update:
I've aquired many more parts including NOS 77 Heads!
Also I've decided to do the car in stages.
Stage 1 get it running as is with the 350/4speed. I want to appreciate the improvements made on the car and get it on the road.
Stage 1 means factory manual drum brakes all around and manual steering and Old suspension (new shocks and sway bar). It will only take a day to clean out the lines, put in the new wheel Cylinders/ master cylinder and get it going.... Or stopping hopefully.
This gives me the opportunity to break in the motor/trans/rear and hopefully sell the engine. It also gives me time to buy all the parts for stage 2.
Stage 2: power steering, power brakes, suspension, engine bay paint, frame painted, big block swap. Essentially the car mechanically in it's final rendition.
Stage 3: exterior paint and interior
Today I dropped off the booster and master cylinder cap to be restored including Cad plating before photo attached. Tomorrow I'm sending the 3856284 water pump to be rebuilt.
Jose Betancourt
67 Camaro L78
Old 04-30-2020, 03:03 AM
jbtech's Avatar
Update:
Unpacked the heads and I'm happy with the purchase. NOS heads with some work done.
Sent the water pump off to get rebuilt.
Also found out the '71 Camaro combination valve can get rebuilt by the same local folks rebuilding the booster and sent that in.
Put a period correct voltage regulator cover on my new voltage regulator.
Jose Betancourt
67 Camaro L78
The Following User Says Thank You to jbtech For This Useful Post:
big gear head (04-30-2020)
  #23
Old 04-30-2020, 03:54 AM
AnthonyS's Avatar
Very Cool!
Old 04-30-2020, 05:32 AM
Things are coming together quickly! Good progress.
Jason
Old 04-30-2020, 12:07 PM
I've been running a set of those 077 heads on my 427 for many years. I'd like to get another set someday for another 427 that I'm wanting to build.
Old 04-30-2020, 07:11 PM
jbtech's Avatar
Luckily the heads I bought were pre helicoiled for the rocker studs. Whoever worked on these cleaned them up nicely and did some preventable maintenance. I'm looking forward to years of service like your heads. If you ever need heads I recommend contacting Jason ( SuperNovaSS ). He is very good at sourcing engine parts.
Jose Betancourt
67 Camaro L78
  #27
Old 05-05-2020, 07:55 PM
jbtech's Avatar
Here are some pics of the NOS crank. My engine builder says he's had this since the early 70's and has been with him through a few marriages.
Jose Betancourt
67 Camaro L78
Old 05-06-2020, 02:37 AM
Ooooh, that’s the best crank. I like how the machinist had it tagged, “MINE”. Good score!
Jason
Old 05-06-2020, 02:46 AM
AnthonyS's Avatar
Hah! ^yep, funny!
Old 05-06-2020, 03:39 PM
resto4u resto4u is offline
body # 70, what is the vin#? very early car, no holes in front subframe rails?
67 Z28, 67 RS/SS 396 Canadian, 73 Camaro Z28/LT Carolina Blue
Tags
1967 camaro, 427, big block, sleeper, z21
