Old 06-07-2020, 06:59 PM
Default 69 Z/28 Day II Project (Air Force Brat)
I've been longing to do a 69 build with a Day II theme so here is the next project dubbed "Air Force Brat". The car is an original X77 sold new at Auran Chevrolet in Minot North Dakota. It's been apart for over 30 years and I purchased it from who I suspect is the 4th owner? He's had it for the past 25 years and it's now on the way up to western Canada where I'll restore the car with my eldest son. I'll dig back through the ownership when time permits and I'm hoping to learn more about the early ownership from it's North Dakota days.
Plans for this build include my son and I creating a righteous yellow on yellow Day II car with all the right parts and pieces to make it into a great little street machine and a throwback to the '70s. Once it's torn down, it's headed straight to the body shop to receive a new trunk pan and have a set of NOS GM quarters installed along with some bodywork. With the body repaired and the shell primed with the jambs painted, it'll come back to us for the underside to be cleaned up and refinished before we start doing the final assembly and paint prep. It will then be sprayed in 76 76 Daytona Yellow lacquer with factory correct stripes before the fun really begins.
Looking to build a righteous small block car with an M22 and some decent gearing inside its original 12 bolt. I have a small stash of Lakewood and NMW parts here and will now be on the hunt for some other period-correct parts to dress this one up nicely. The idea for the name for the car comes from it being sold right outside of Minot AFB. It leaves me to wonder if a pilot or base worker may have bought this car new? I'm sure it was well known with its yellow Houndstooth interior, options group and the Z/28 badges. The original engine and trans were both scattered back in 1974, so it will now make for a great day II car, and once complete it should be a total Brat!
My son did a little artwork and designed a front plate that we'll put on the car when it's done.
The car has a GM cowl hood and all evidence supports it being an original ZL2 optioned car.
Original X77 car in Daytona Yellow with Yellow roof and matching yellow interior.
The rockers on both sides are in excellent condition as are the interior floors.
The drivers' door was replaced from an accident occurring long ago. Original 4 speed tunnel is clean but not sure what Day II gas pedal is in there?
I may struggle with the yellow interior. I don't mind the original yellow, but not a fan of the bright repro colors. Might take a run at restoring the originals.
The original DY overspray can still be seen on the underside. I'll know more when it's here but I may try and save the underside.
One of 188 Camaro's to receive this V75 option for Liquid Tire Chain. On the hunt for an original system now...
The original 12 bolt BU diff dated Feb 24th. This will be rebuilt with some better gearing for the street and already has a Day II cover!
Rear bulkhead with the original X 7 crayon marking visible to the eye. Should reveal better after some cleaning.
Original trim tag still intact. I'm not sure about the filler inside the rivets and will need to see if that's the factory resin?
Rear tail panel is in excellent shape. The car does not have much rust showing anywhere.
Auran Chevrolet was the original dealer. It was taken over by Jim Ryan in 1973. His daughter now runs it as Ryan Buick GMC
Found this dealer tag on eBay and will add this to the rear panel after it's painted.
Original GM quarters that were bought for the car back in the late '90s by the seller. They were purchased with the car.
Both have their original paper tags on the inside and will be used when the body's restored.
Stay tuned as more plans for the car unfold over the weeks and months ahead. As always, I invite your feedback and suggestions for the Day II appointments.
The Following 14 Users Say Thank You to NorCam For This Useful Post:
big gear head (06-07-2020), Crush (06-07-2020), Damien (07-02-2020), dykstra (08-06-2020), HawkX66 (06-08-2020), L_e_e (06-07-2020), markinnaples (06-08-2020), RobR (06-08-2020), RPOLS3 (06-08-2020), Rumbleguts396 (06-07-2020), Spooky (06-07-2020), Tenney (06-07-2020), YENKO DEUCE REGISTRY (07-03-2020), ZAPPER68 (06-08-2020)
Attachments - The Supercar Registry ZSalesDoc.jpg wedge.JPG We're not worthy.jpg VGvsRamRod.JPG
Old 06-07-2020, 07:26 PM
Zedder's Avatar
Zedder Zedder is offline
Can’t wait to follow along Graeme!
Mark
The Following User Says Thank You to Zedder For This Useful Post:
NorCam (06-07-2020)
Old 06-07-2020, 07:51 PM
TimG TimG is online now
It will be fun to watch the build. I vote for the yellow hounds-tooth interior, that looks great.
The Following 2 Users Say Thank You to TimG For This Useful Post:
NorCam (06-07-2020), thomam (11-26-2020)
Old 06-07-2020, 08:28 PM
Very nice project ! Will be fun to follow for sure!
The Following User Says Thank You to chevelleheart For This Useful Post:
NorCam (06-07-2020)
Old 06-07-2020, 09:57 PM
Do you plan on building a 302 for it or will it be something larger?
Old 06-07-2020, 10:17 PM
Zedder's Avatar
Gotta be a 302 with the yellow guts!
Mark
Old 06-07-2020, 10:42 PM
Rumbleguts396 Rumbleguts396 is online now
I cant wait to watch and follow along also. You do some real quality work and attention to detail. Bad thing is now I have competition again on those Day 2 parts in the for sale section !!!! ROB
1969 Camaro SS 396 X66 Lemans Blue
1969 Corvette 427/390 Lemans Blue
The Following User Says Thank You to Rumbleguts396 For This Useful Post:
NorCam (06-07-2020)
Old 06-07-2020, 10:49 PM
Still have this solid roller motor and plan to make use of it in the Camaro. It's a balanced and blueprinted 360ci build with a forged crank, Manley 4340 rods, Manley 2618 Pistons, Modified 200cc Aluminum Heads, and a Lunati Mechanical Roller @ 254/262 duration. It's built to run 7500 rpm and the heads are set up with Crower stainless rockers. I could also keep it a bit stock looking with an original 472 intake, stock covers, and an original cowl breather with a good mechanical carb tucked underneath it. I need to get a nice M22 or an M23 to run in behind it.
flyingn (01-21-2021), vince (02-11-2021)
Old 06-07-2020, 10:57 PM
LOL...lately I watch the stuff selling on FB and shake my head at some of the prices. Good thing is I've been hanging onto some good vintage stuff here that I do plan to use.
Old 06-07-2020, 11:05 PM
COPO COPO is offline
I like the idea of a stoutly built motor, but dressed up to look mostly stock. Perhaps even paint the AL heads orange in addition to the finned VC's and 472 intake.
The Following User Says Thank You to COPO For This Useful Post:
NorCam (06-08-2020)
