Old 06-14-2020, 10:21 PM
A12pilot's Avatar
A12pilot A12pilot is offline
Oh yeah, Ryan. This car ain’t going nowhere! I’m now planning on making two, but still, no way either will leave!
Yes, I keep telling you to come down here and when I get a YYZ overnight I’m calling ya!
Cheers
Dave
Old 06-21-2020, 02:55 PM
A12pilot's Avatar
This rear is getting more work done to it than a farmer's daughter in an adult film!
Tail light positioning and I'm liking the lines back here more and more. I'm going to massage a template for the edges of the rear quarter to make sure they are symmetrical. Right now, it looks pretty good. License plate relief and trunk opening are there too.
I'm hoping by the end of next month the car will be filled and primed. I need to make a steel frame with rollers to position this on since the weight of this thing is more than I thought!
I'm closing in on buying the donor car too!
More to come....
Cheers
Dave
The Following 6 Users Say Thank You to A12pilot For This Useful Post:
67 Nova Boy (11-16-2023), big gear head (06-21-2020), Chazman (11-19-2023), dykstra (06-23-2020), markinnaples (06-22-2020), Woj (06-23-2020)
  #213
Old 06-24-2020, 10:49 PM
A12pilot's Avatar
Headlight bucket time! In studying the whole front end, I needed to recess those headlight buckets and also extend the cap a little bit further. This added the extra lip I needed as well as the angle now being correct.
Every little step is a big move forward. This took a good day to get it right. I'm describe it more in detail once I get it fitted up. More to come!
Cheers
Dave
67 Nova Boy (11-16-2023), big gear head (06-25-2020), Billohio (06-25-2020), dykstra (07-06-2020), markinnaples (06-25-2020), PeteLeathersac (06-25-2020)
  #214
Old 06-25-2020, 11:50 AM
TimG TimG is offline
Great work, Dave. I enjoy your updates.
Old 06-25-2020, 10:05 PM
A12pilot's Avatar
Thanks, Tim. That means a lot! Hopefully you’ll see it in person one day!
Cheers
Dave
Old 07-01-2020, 02:36 PM
Saw these pics on FB Dave so I thought I would share them for motivation (which is moot I guess when I'm talking to you, lol).
John 10:30
The Following 2 Users Say Thank You to markinnaples For This Useful Post:
67 Nova Boy (11-16-2023), PeteLeathersac (07-18-2020)
  #217
Old 07-01-2020, 06:48 PM
A12pilot's Avatar
Thanks for posting those, Mark! Yes, motivation is lacking around here for sure
I’m not sure of the show, but they have the BIGGEST show ID passes I’ve ever seen!
Cheers
Dave
The Following User Says Thank You to A12pilot For This Useful Post:
markinnaples (07-01-2020)
  #218
Old 07-01-2020, 08:08 PM
----Not sure either, but the backround looks like Amelia Island! Beautiful Beemer too!!!...……...Bill S
Old 07-17-2020, 12:10 PM
A12pilot's Avatar
Windshield is in! Woohoo! Very pleased with the look and it's a quality piece. I'm in talks with a company that may make the bumpers for the car too. Right now, they do make 503 bumpers and I'd have to alter the rear to make it fit. The 507 was based off the 503 so the dimensions are quite similar.
Moving forward!
Cheers
Dave
67 Nova Boy (11-16-2023), dykstra (07-21-2020), markinnaples (07-17-2020), olredalert (07-17-2020), PeteLeathersac (07-18-2020), RPOLS3 (07-17-2020)
  #220
Old 08-15-2020, 02:17 AM
A12pilot's Avatar
Finally back making some progress and with that, the dash arrived from Stuttgart. I believe that's where the ball bearing plant usually got bombed in Hogan's Heros, but that may be Heidelberg.
This was molded off a real 507 dash so it's true to form and scale. The gauge pod needs to be fabricated (what doesn't? ) and for ease, I created a mock up of that part so I could fasten the dash together.
I removed the windshield frame and continued filling the body. Next step is to sand smooth then lay one 6oz fiberglass mat on top to hold it all together. After that, I'll use more filler to get the final body shape. Right now, I need to sure up the structure so it doesn't shift or crack when moving, and the mat will do that. But I need to cover the foam with filler since the resin will melt the foam. It's melting the foam a little since I'm not using epoxy resin. For this, the cheaper is better.
More to come...
Cheers
Dave
The Following 5 Users Say Thank You to A12pilot For This Useful Post:
67 Nova Boy (11-16-2023), big gear head (08-15-2020), dykstra (08-18-2020), markinnaples (08-15-2020), Xplantdad (08-15-2020)
