Go Back   The Supercar Registry > Comments/Suggestions > Comments, Suggestions, Problems
Old 06-29-2020, 05:27 PM
m22mike's Avatar
m22mike m22mike is offline
Default smiles in posts
What am I missing here ? I have smiles turned on in used CP, I think, but there not there when I post.
Old 06-29-2020, 05:37 PM
Old 07-01-2020, 01:52 AM
A12pilot's Avatar
A12pilot A12pilot is offline
Geeze, Mikey. You can rebuild a JT8-D, but you can’t figure out smileys? It’s quite simple. Go to your user profile under the tabs function of the pulldown menu in the upper right hand sub menu under settings. Select the functions button, then scroll upwards until you’re below the thread modifier. Once there, click on the enable button which should allow you to select the drop down menu of selections based on what you selected. Click next, the back. You should be set!
If you need help, please send the administrator an email. It’s simple. To do this, click the menu button on the right side of the upper left screen window tab. Scroll downwards until you’re past the screen functions settings in the control tab. Hit communicate, then message, then scroll to a menu to free text. Then just simply send your message.
Sound good?
Cheers
Dave
