Old 07-04-2020, 01:28 AM
A12pilot's Avatar
A12pilot A12pilot is offline
Hi Freddie,
You are correct. No masking done at the factory when it came to painting the car. It was painted assembled as one piece, therefore, interior and such all got overspray and a light coating of color.
Since I’m painting it in stages, I mask off what was already painted so overspray doesn’t get on the fresh clear, that’s all that’s for. Once unmasked, it’ll all look like it was painted as one piece. I do it in stages since painting everything at once is at least a 12hr process from start to finish. And, I’d be 105lbs and probably dead afterwards! Doing it like this makes it manageable, I’m not rushed, and I can concentrate on the task rather than feel overwhelmed by how much painting is ahead of me. I may do the door jambs over the weekend if I don’t have to fly and then the only thing left will be the exterior.
A unique thing I did was hang the fender tag from the window channel by the factory parts tag remnant that was originally there. It made for a good hook to hang it on. On this car, the tag was secured to the inner fender with a screw and then bent up while painting. After paint, the tag was bent back and the other end fastened with another screw that was unpainted. I installed a screw on the inner fender and painted it while doing the engine bay. Now it’ll look correct when installed with a slight bend on the corner with a painted screw, and the other end an unpainted screw!
My Super Bee was a Lynch Road car and as such, the tag was hung on the window channel or column mount and could have received only a dusting of color, no color, or a lot of color. Just depends on what the painter did. No bend in the tag and no painted screws.
Neat stuff!!
Cheers
Dave
The Following 7 Users Say Thank You to A12pilot For This Useful Post:
427TJ (07-04-2020), big gear head (07-04-2020), L_e_e (07-04-2020), markinnaples (07-04-2020), olredalert (07-04-2020), PeteLeathersac (07-04-2020), sixt9rsx33 (07-04-2020)
  #482
Old 07-04-2020, 10:13 PM
napa68 napa68 is offline
For a body guy, you're not a bad pilot!
Old 07-05-2020, 11:38 AM
A12pilot's Avatar
Well, thanks! But shouldn't that be "For a pilot, you're not a bad body guy! "
But speaking of that, I had to do that pilot thing yesterday (of course) due to some repositioning of aircraft around or system. Packed flights... that's a good thing for job security!
So today the door jambs get painted and here's the details on the fender tag. You can see the slight bend in the tag on the left side with the painted screw.
Cheers
Dave
The Following 2 Users Say Thank You to A12pilot For This Useful Post:
big gear head (07-05-2020), markinnaples (07-05-2020)
  #484
Old 07-05-2020, 12:37 PM
njsteve njsteve is offline
Gotta love those details! Even the original, assembly line, dome-headed screws, too. One painted, one natural finish.
Old 07-05-2020, 01:33 PM
TimG TimG is offline
After seeing your restoration work, I'd trust you in any aircraft, Dave.
Old 07-05-2020, 04:12 PM
A12pilot's Avatar
Thanks for that, Tim! If I know you're on the plane I'll insist on complimentary adult beverages!
Yep, Steve-O! See that little notch on the fender tag? Original! Jambs are waiting on clear as we speak! Going to start ripping apart the suspension later today as we discussed and start blasting the parts.
More soon....
Cheers
Dave
Old 07-05-2020, 05:33 PM
Roger that! Already searching the interwebs for parts. I have been hearing horror stories about Moog lower control arm bushings for mopars not being manufactured to the right size in the past few years, so I am looking for alternatives. (the inner diameter where the stud is pressed in, was built too loose and the stud just spins. Anyone else heard about this?)
Old 07-05-2020, 08:17 PM
A12pilot's Avatar
I haven't had any issues with those but I haven't done them since the Bee. I guess we'll find out! And if anyone can have issues..... it's me!
Jambs are painted! While that was curing and with nothing else to do, I jumped over and disassembled the suspension in preps for blasting, replacing, and detailing.
Also found this green marking on the idle arm mount when I pulled it off. I've seen this green mark before on Hamtramck cars and St. Louis cars but it's usually on the engine mount point on the a-frame.
It'll go back like original! Gotta lift the engine then pull the k-frame out to start the cleaning and repaint.
More to come...
Cheers
Dave
The Following 10 Users Say Thank You to A12pilot For This Useful Post:
427TJ (07-06-2020), 69b5bee (07-05-2020), big gear head (07-05-2020), COPO (07-06-2020), KLars1 (07-05-2020), markinnaples (07-06-2020), napa68 (07-06-2020), olredalert (07-05-2020), PeteLeathersac (07-06-2020), X66 714 (07-05-2020)
  #489
Old 07-06-2020, 01:15 PM
RS_COPO_Canuck RS_COPO_Canuck is offline
Originally Posted by A12pilot View Post
See? That's what makes you my idol, Jim. It's the details like that! Didn't know that about the 70 trunk latch and yes, mine was painted. Did they use a different hook or something? Wonder why the change. I have that factory diagram about the cowl blackout, and mine had it from what I can tell by the sleuthing I did. Any idea when it stopped being done on the cowl?
Engine bay painted! Might do the door jambs tomorrow but I'm on call the next three days, then out to Taylorsville, IL to get my Flight Instructor rating reinstated. Been trying to do this for almost a year and the latest fiasco was this stupid cough. But so far it's a go! Plus, I need another gallon of FC7 and the paint shop was closed today.
More to come!
Cheers
Dave
Yes Dave, they used a different setup to keep the trunk down....but evidently decided it was a little quicker just painting the trunk latch.
Late, late cars skipped the cowl blackout in 70. 71's didn't have it.
All my purple cars had headlight, rad cradle area blackout. The bottom of the rad cradle didn't get hit...with blackout and pretty well no body color. It should show mostly dip color and maybe a misting of purple.
The correct way to do the cowl and rad/headlight area blackout is have 6-8 beers and have Beck's Bolero blasting through your speakers. No masking! Although you have to really like factory sloppy! Hood hinges almost always show overspray from the cowl blackout procedure.
A lot of cars had battery tray blackout as well. Some neat, some not so much!
The Following User Says Thank You to RS_COPO_Canuck For This Useful Post:
  #490
Old 07-06-2020, 01:23 PM
Cowl and rad area
