Old 09-16-2020, 01:54 AM
ALLZS ALLZS is online now
Default Starters
On a 69 smallblock 302 starter was the noise cone housing aluminum or the cast iron housing most of the stick shift starter i have seen have the cast iron housing
Old 09-16-2020, 02:32 AM
McCune McCune is offline
Did the 69 Z have a 11" clutch?
Old 09-16-2020, 02:34 AM
The 1108367 starter has the Aluminium short bolt, long bolt drive end housing.
Old 09-16-2020, 10:48 AM
JRSully JRSully is offline
Does anybody have a link to Chevy starter P/N's, specifically nose pieces.? I have a lot of old starters that I either need to sell or scrap, but need to ID prior. Thx in advance
71 Porsche 911 Targa
Old 09-16-2020, 11:26 AM
KevinW KevinW is offline
Do nose pieces have casting numbers? I have only seen the Application Number stamped in the steel body. The Motors Books ( I have a few) have starter Applications numbers in them, but not much info about the nose.
69 327 convertible (driver)
Old 09-16-2020, 02:16 PM
John Brown's Avatar
No. There may be i.d. numbers on them, but nothing like casting numbers as used on blocks/heads etc.
John Brown
Old 09-16-2020, 03:11 PM
1969 Z28's had the 10.5 inch clutch
Owned since 1978 - First Car
Old 09-16-2020, 04:44 PM
That is why it uses the Cast Aluminum long bolt short bolt housting. The cast iron housing is used on the bigger flywheel.
