Old 09-12-2020, 05:41 PM
Default 1969 Z28 Data plate
I am looking at this car, what can you tell me about the data plate? It seems funky
Attachments - The Supercar Registry IMG_5043.jpg IMG_5042.jpg IMG_5041.JPG IMG_5017.JPG
Old 09-12-2020, 06:08 PM
X66 714's Avatar
X66 714 X66 714 is offline
Los Angeles car. Not much to tell except paint, trim & date....Joe
http://www.camaros.org/numbers.shtml
Old 09-12-2020, 07:48 PM
Jonesy's Avatar
Jonesy Jonesy is offline
Looks like an azure turquoise car with black interior.
Old 09-14-2020, 08:20 PM
Does anyone know what the F106 on the bottom right is?
Old 09-14-2020, 09:33 PM
Jonesy's Avatar
Van Nuys plant, body scheduling code. Not really relevant to anything important
The Following User Says Thank You to Jonesy For This Useful Post:
chevyandpontiac (09-14-2020)
Old 09-16-2020, 05:56 PM
I have received more paperwork and pictures. Always looking for thought on this car.
The car is painted the wrong color currently, suppose to be a real deal 1969 z28 .
1969 z 28, factory original rare endura bumper . this is a cal. car . number matching engine and rear end. trans is a CE factory replacement. have broadcast sheet and pop. one re-paint in 1981. second owner had it from 1982-2016. car is a awesome driver quality rust free car. all original sheet metal, original interior. has some cracks in paint, mainly in the black stripe area. needs trunk gasket, door gaskets are original. dash pad is rolled up by windshield
Old 09-16-2020, 05:59 PM
and here is picture of the car. It has been a hot rod, wrong hurst shifter after market gauge . mallory coil. wrong exhaust manifolds.
The Following 3 Users Say Thank You to chevyandpontiac For This Useful Post:
cruiserofland (09-16-2020), Jonesy (09-16-2020), L72Chevelle (09-19-2020)
Old 09-16-2020, 06:17 PM
William William is offline
That's a transferred warranty plate; no DT codes on it. Pretty much useless.
Block stamps may be ok, need to get the paint stripped off the pad. Also need pics of the carb, alternator, distributor, radiator. Each one would be $1000+ to correct. Rear axle?
Those are Corvette wheels w/incorrect tires; aftermarket rear antenna.
Figure about $20k to correct the paint, wheels, tires, dash pad.
The Following User Says Thank You to William For This Useful Post:
chevyandpontiac (09-16-2020)
Old 09-16-2020, 07:47 PM
Crush Crush is offline
That’s what I call a tidy summary!
The Following User Says Thank You to Crush For This Useful Post:
Carolina Dreamin' (09-18-2020)
Old 09-16-2020, 07:55 PM
jdv69z's Avatar
jdv69z jdv69z is offline
So if that is the chassis broadcast sheet for this car, I see several codes listed that would indicate Z/28; Radiator, water pump pulley, alternator, front springs.
Jimmy V.
The Following User Says Thank You to jdv69z For This Useful Post:
