  #11
Old 09-30-2020, 07:45 PM
earntaz earntaz is offline
Originally Posted by SS427 View Post
You will want it fully submerged. If not you will get a liquid parting line on the metal which is hard to make look good and/or disappear. Within the PVC tube, once the shaft is put inside it will not require a lot of Evaporust to encase it. My tube is 59" long (I disassemble u-joints before soaking) and 4" inside diameter white PVC.
^^^^ Make sure to measure your driveshaft and add about 2 inches. Glue one end cap on and make sure you can remove the other end cap. You may have sand the pipe some. Make sure you have all the grease and other contamination removed before soaking. I left my driveshaft in over night and it looked brand new the next day. TAZ
