Old 10-07-2020, 09:04 PM
whitetop whitetop is offline
Originally Posted by KevinW View Post
So anyone figure out a way to thicken it for vertical surfaces, i.e. Navel Jelly consistency?
I draped a thick towel over ,my old tractor fenders which has some slight to moderate surface rust and soaked the towel with Evaporust. 2 days and it took off all the rust. The downside of doing it this way is you waste the material but it works.
Old 10-08-2020, 12:53 PM
KevinW KevinW is offline
Originally Posted by njsteve View Post
Evaporust recently came out with a gel version for this application.
Thanks Steve and others. Will have to try this out! K
69 327 convertible (driver)
Old 10-08-2020, 01:44 PM
If you soak a towel or fiber cloth, you can put a layer of plastic over it to stop it from drying up as fast. Helps prolong evaporation. The same thing applies to putting E-R into a trough to layout longer parts. Again, cover it with plastic.
napa68 (10-08-2020)
  #34
Old 10-08-2020, 05:04 PM
cook_dw's Avatar
cook_dw cook_dw is offline
Here's a teaser. Cleaned, degreased and evapo'd. No repainting or refinishing of any kind. I'll share products and processes once the car is finished.
The Following 5 Users Say Thank You to cook_dw For This Useful Post:
69b5bee (10-09-2020), hurstL78 (10-13-2020), RPOLS3 (10-09-2020), Tracker1 (10-10-2020), X66 714 (10-09-2020)
  #35
Old 10-09-2020, 01:54 PM
I have an old Holley carburetor that's pretty carboned up, would Evaporust be acceptable to use for this purpose or no?
John 10:30
Old 10-09-2020, 02:27 PM
njsteve njsteve is offline
It only works on ferric metals. Iron, steel etc. it will remove the colored plating from a carb and might actually eat the carb metal up. I wouldn’t put a carb in evaporust.
Old 10-11-2020, 06:45 PM
We look forward Darrell!
68,69&2015 Z/28's
Few Corvettes
The Following User Says Thank You to 68camaroz28 For This Useful Post:
cook_dw (10-12-2020)
  #38
Old 10-12-2020, 06:54 PM
That looks so good Darrell...
  #39
Old 10-18-2020, 08:53 PM
I've been using the stuff like Frank's red hot and put everything in it.
...and it's flat out excellent for cleaning seats belts without ever disturbing the ink on the dated tags or printed labels.
Can you give us more detail on the process? Did you clean them in soap and water first? I'm ready to work on the 'cuda seat belt set next...
Old 10-18-2020, 09:13 PM
Default Axle flanges
Axles in Evaporust tub
Owned since 1978 - First Car
