Old 10-12-2020, 09:19 PM
X66 714's Avatar
X66 714 X66 714 is offline
I think I have the chrome tail pipes looking as good as possible considering they were probably flash chromed like other pieces. I will use a little silver header paint to add a little color to the areas that weren't polished before chroming.
I took to the exhaust head pipes & the pipes that go over the axle to the place that does my powder coating. They use a high heat product called Cerakote for headers so it should be just fine for the head pipes. Found a color that hopefully is close to new exhaust tubing. I'll post some pictures when they return
Found the X6 that has been discussed about Norwood cars....Joe
ZLP955 (10-13-2020)
  #122
Old 10-14-2020, 03:16 AM
X66 714's Avatar
Waiting for the exhaust to come back, here's some of the rearend. It was in good shape & original to the car. Killer 3.07 single track. Left everything stock. All powder coated with BK02 Cardinal. Closest match I could find to original pieces. Arizona plays nice with some of the chassis pieces....Joe
The Following 5 Users Say Thank You to X66 714 For This Useful Post:
NorCam (10-14-2020), olredalert (10-14-2020), RPOLS3 (10-16-2020), ScottG (10-21-2020), Xplantdad (10-14-2020)
  #123
Old 10-14-2020, 03:21 AM
X66 714's Avatar
The original leaf springs were soaked in evap-o-rust, washed completely & then hit with 0000 steel wool. Sprayed lightly with satin clear. NOS bushings used in the forward eyes. (I hope I put the spring decals in the correct place)...Joe
The Following 2 Users Say Thank You to X66 714 For This Useful Post:
HawkX66 (08-11-2023), NorCam (10-14-2020)
  #124
Old 10-14-2020, 03:29 AM
X66 714's Avatar
The car being from Tucson, all the hardware & brackets were in great condition. Original "S" shackles & bolts/nuts & NOS bushings. Original spring pockets. Original spring plates & brake cable guides. I also have NOS spring pads. All powdered back to original color. Managed to scare up some original "832" rear shocks....Joe
big gear head (10-14-2020), cruiserofland (10-14-2020), HawkX66 (10-19-2020), NorCam (10-14-2020), RPOLS3 (10-16-2020)
  #125
Old 10-14-2020, 03:45 AM
Looking really good Joe. The diff housing looks terrific and I really like the clear look on the springs. I'm sure you're busy trying to decide what to put where and what to do first.
G.
Old 10-14-2020, 11:08 AM
X66 714's Avatar
G.
Thank you Graeme. Actually I've been stuck at my step daughter's house helping her put her new kitchen together.
Once the exhaust comes back, I want to install it & all the rearend pieces. At that point I can get one end off the cart....Joe
NorCam (10-14-2020)
  #127
Old 10-14-2020, 01:22 PM
duskblue duskblue is offline
Looking good Joe
Old 10-14-2020, 01:58 PM
X66 714's Avatar
Thank you Guy. I have a bunch of bolts to redo. That will be starting today...Joe
Old 10-14-2020, 05:46 PM
Joe, looking really nice. Spring decals are in the proper location.
All of the NOS leaf springs I have seen, have a bluish tint from the heat treat.
- Warren
The Following User Says Thank You to WorkinProgress For This Useful Post:
X66 714 (10-14-2020)
  #130
Old 10-15-2020, 09:49 PM
X66 714's Avatar
Over the last couple of days, I've been putting together bolts & items that require phosphate coating. I put them on this cardboard so when I'm done with the process, they can go back to the board....Joe
The Following 7 Users Say Thank You to X66 714 For This Useful Post:
big gear head (10-16-2020), HawkX66 (10-19-2020), mockingbird812 (10-31-2020), napa68 (10-20-2020), NorCam (10-16-2020), RPOLS3 (10-16-2020), ZLP955 (10-23-2020)
