Hi everyone,
Just bought a '67 Camaro real 4K L78 car. Already hate the Muncie shifter as it is now bound up in reverse. Fortunately, I was able to back into my garage and I'll have to get under this weekend and get it unlocked. Plan is to order a Hurst Competition Plus shifter and linkage kit (pretty spendy over $700) and then cut the shifter handle off and weld the Muncie stick to it as I am a purist and want to maintain the stock look. Seems straightforward enough. Any concerns guys or tips? Thanks, Paul
Paul '62 Bel Air 409/409 '63 Impala SS 409/340 convertible '68 L72 Biscayne '69 L78 Nova '17 Denali 3500HD |
I am pretty sure you can purchase a reproduction Muncie handle that is already made to fit the Hurst shifter mechanism. You won't ruin your original handle and is less expensive then rechroming the one you cut and weld. They make them for the Chevelle so likely made for the Camaro as well.
Rick Nelson Musclecar Restoration and Design, Inc (retired) www.musclecarrestorationanddesign.com https://www.youtube.com/watch?v=62r-6vgk2_8 specialized in (only real) LS6 Chevelle restorations |
A 67 Camaro factory handle can be cut off & drilled to match the Hurst shifter stub, unless you want to save it, like Rick said they may make a handle now. Hurst pricing has got stupid in last few yrs.
Mike |
This is what I did (cut and drilled) with my shifter and it was pretty easy.
Robert _______________ 1969 Chevelle SS396 L78 M21 4.10 2023 Stingray Coupe Z51 |
Paul, I am in the exact same situation. Finding it Difficult on taking the Death=Wheel to my Org "MUNCIE" chrom plated handle.
I bought the Plated version of the 67/68 shifter then ordered a 3/8UNC 'chrome' ball. Also picked up: Hardened Bushing and properly sized New Clips Source 5SPEEDS.COM I am not positive they are Making a "F" Body Handle yet, I might have not looked hard enough tho. Anybody got the Source and Part number for this Muncie Logo Hurst handle? (I have see Chevelle Handles of this description from the ("Parts Place") Jim
69 Los Z11 68 SS/RS 396/325 68 Los Z28 ![]() |
Maybe Joe at the parts place repos it or should? I thought Ground Up reproduced it before ? How close is a Chevelle handle shape?
Thanks for the tips guys. I have the Hurst on order. Will let you know how it goes.
Glad to see you are installing a Hurst , I dought you will ever go back .
Well, installing a Hurst, but making it appear to be a Muncie! But yeah, need to be able to shift this thing!
I did the same thing with mine, but it's harden steel. I used a high speed drill bit for the holes. It will sit a little higher than stock, but you'll be the only one that knows it.
Thread Tools | |
Display Modes | |
