Old 11-11-2020, 01:31 PM
Unreal Unreal is offline
I'm no expert, but it seems to me that in the past, it was recommended that you primer the grille first, with a greyish white primer, and then follow with the argent. Not only do the tabs and such look correct, but the tone of the argent is closer to original. Sorry, I don't know the color codes.
Old 11-11-2020, 01:47 PM
Bone.
Old 11-11-2020, 02:47 PM
Jonesy's Avatar
Jonesy Jonesy is offline
I have the grille out. Its an original black one. Im going to scuff it up and try the SEM custom mix in a spot on the back and see how it compares to my headlight bezels.
We will see how this goes
Old 11-11-2020, 04:04 PM
x33rs x33rs is offline
Yes you can certainly have any color mixed and installed in a spray can. Any paint store worth anything can do this for you. It's great for guys that don't have a gun or a means to mix their own paint.
I've had it done many times for customers when I was painting tube chassis cars for a fabrication shop. They wanted little aerosol cans to touch up the roll bars as they get scratched getting in and out, flopping the seat belts around etc...
So if you want a custom urethane paint, Omni, or what ever brand mixed up in a spray can, that's probably the simplest and cheapest solution for guys wanting to shoot small parts.
Old 11-11-2020, 05:08 PM
Yes, most paint stores can put the single stage products in a spray can for you.
My grill was an NOS black grill. I primed it with white epoxy, so that if there were a small chip in the silver, it wouldn't be as noticeable.
Old 11-12-2020, 01:31 PM
enio45 enio45 is offline
Jonesy, one of the things i did, although on an orig bone color grill was to totally refinish the grill, we completely repainted it the same bone color (customers mix) - then we followed up with the silver, and then the body color overspray on the surround. Looks 100% original. The bone color will help with the silver coverage most effectively.
Also - if you go silver over black then for sure your headlamp bezels will be slightly off....I would suggest a quick respray of those as well. Light scuff and reshoot to get that consistency.
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 11-22-2020, 06:40 PM
Jonesy's Avatar
Well I went to the auto body supply shop here.
They looked up PPG 3568 and it’s 1983 Ford Mercury Loden Green.
I definitely did not have that mixed
Lynn are you sure about that paint code?
Old 11-22-2020, 08:36 PM
m22mike's Avatar
m22mike m22mike is offline
Ppg 8568
Old 11-23-2020, 03:41 AM
Jonesy's Avatar
Thanks Mike. I give it a try.
Old 11-23-2020, 08:40 PM
X77Z28MP X77Z28MP is offline
Question z28 69 camaro grill
I know this doesn't belong here but im going to ask. I need to buy a aftermarket 69 camaro grill for a Z28 Can anyone recommend where i can find a good fitting grill > thanks in advance
69Z X77 03D Lamans Blue
