Adding to the restoration pics and the storyline of the undersides, I had Ron apply some overspray and satin black paint to the primer sealed underbody. While much of the rear section and tunnel area is prominently sealed in grey primer, the lower floorboards were painted black with the heaviest emphasis being up near the toeboards before painting the satin black firewall.
He then painted the lower rockers and rear wheel openings in yellow without being overly protective of getting any overspray onto the floor edges or the areas beyond the targeted pattern in an attempt to mimic what the factory did. Yellow overspray can now be seen where typically found on the factory painted cars including some overspray of the black sound deadener applied to the wheel well areas. I'm fairly happy with the end results and didn't want to over restore the car or get too carried away with overspray. ![]() Yellow overspray seen on the lower floors here. The label still needs to be removed from the added subframe connectors and they need some welding at the rears. ![]() Restored original 12 bolt rear with Cal Custom Cover and vintage Lakewood Trac Bars (Decal was a fun touch to be added) ![]() Here you can see the yellow overspray in the tunnel area from the outer frame rails being sprayed. ![]() The same overspray patterns are found on both sides of the rear tunnel. ![]() Lots of overspray under the tank mounting areas and on the leading edges of the lower trunk pan. Fuel lines were added after the fact. ![]() Here you can see yellow overspray and some sound deadener residue over the black on the rear of the floor pans. (non-deliberate effect) ![]() The transmission tunnel is seen with exposed primer between the lower floor pans. The tunnel hole was torch cut into the new floor and rivnuts added. ![]() Here are the lower firewall sections looking back where most of the central area is satin black (except in the tunnel area).
I like solid lifter cars, big cams and cars w/ 3 pedals in them. ![]() Last edited by NorCam; 12-06-2020 at 04:26 PM. |
The Following 8 Users Say Thank You to NorCam For This Useful Post: | ||
big gear head (12-06-2020), cruiserofland (12-06-2020), dykstra (12-08-2020), gtomike1967 (12-06-2020), KLars1 (12-06-2020), L_e_e (12-06-2020), R68GTO (12-06-2020), X66 714 (12-06-2020) |
Thread Tools | |
Display Modes | |
