Old 12-08-2020, 04:21 PM
nova67 nova67 is offline
Default grille emblem
Joe...the Emblems I have are 3982043 in a box with part number3981921 and the other one the number cast on back of Emblem is 3986590 Tom
The Following User Says Thank You to nova67 For This Useful Post:
X66 714 (12-08-2020)
  #12
Old 12-08-2020, 04:49 PM
X66 714's Avatar
X66 714 X66 714 is offline
Tom. Since you have 2 different numbers, how does the length on the pins compare? Are the 590 pins longer by chance? Thank you, Joe
Old 12-08-2020, 05:08 PM
Jonesy's Avatar
Jonesy Jonesy is offline
3958640 was the original part number
it was discontinued and replaced with 3958638.
3958638 then showed up as use part number 3981921 by 1981.
3981921 is also the SS emblem for the 70-72 Camaro. This may be why the studs are shorter.
Old 12-08-2020, 06:00 PM
X66 714's Avatar
3958640 was the first part number for a 69 SS with R/S.
3958638 was the first part number for a 69 SS w/o R/S
Why the 640 was superseded to the 638 makes no sense
I would like to know what the casting number was on the 3958638
The 6263015 has a casting of 3986590
The 3981921 has a casting of 3982043
The assm line installed SS emblem has a casting of 3943229
I'm wondering if the 3958638 shares the 3943229
Research sometimes is a pain. Thank you, Joe
Old 12-08-2020, 08:07 PM
cdn454LS6 cdn454LS6 is offline
The one I have in the box is cast 229 and the box says 638
The Following User Says Thank You to cdn454LS6 For This Useful Post:
  #16
Old 12-08-2020, 09:04 PM
X66 714's Avatar
Sent you a PM...Thank you, Joe
Old 12-11-2020, 02:28 AM
Default 69 Grille emblem
Joe I will measure the pins this wknd and let you know. Tom
X66 714 (12-11-2020)
