Old 12-16-2020, 01:55 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
03C built 1972 Chevelle Big Block (Tonawanda) Engine cast 3/1/72 assembled 3/14/72. Both heads cast 3/8/72
Jake Dykstra
Dykstra Motorsports
Old 12-16-2020, 02:58 PM
mprice mprice is offline
I agree with everything stated here I see nothing wrong with your dates but remember there are very few absolutes when it comes to these dates. I have seen junkyard motors from 69 chevelles that were cast 7 months before they were stamped. Inventory rotation was not a high priority at GM in those days.
Old 12-16-2020, 05:00 PM
William William is offline
True.
Not unusual for 512 blocks cast in January [A49] to be used for COPO L72 engines assembled in April.
Z/28s were a different story. Early in the MY, not unusual to see engines final-assembled the day after the block was cast. Also, have two later examples cast & assembled the same day.
Heard a story about '67 Corvettes with the standard 300/327 engine. Chevy needed to convert the intake manifold tooling. They ran off all the castings needed for the '67 MY Fall '66 and shut it down. No matter when the engine ended up getting built, it will have an intake manifold cast August or September '66.
The Following 2 Users Say Thank You to William For This Useful Post:
RPOLS3 (12-16-2020), Xplantdad (12-16-2020)
  #14
Old 12-16-2020, 08:38 PM
Our old VO409DZ was cast April the 7th.
Old 12-17-2020, 01:39 PM
jdv69z's Avatar
jdv69z jdv69z is offline
Originally Posted by ALLZS View Post
my 09D OF 1968 IS CAST I-11-8 BUILD VO912DZ
My 10B 302 is almost an exact match. I 10 8 cast, V0912DZ assembly. Same batch of 302's I think? Does your stamping look like mine?
Jimmy V.
Old 12-17-2020, 01:55 PM
HawkX66's Avatar
HawkX66 HawkX66 is offline
Originally Posted by SeattleCarGuy View Post
Friend is looking at a '69 Camaro. Its an 11D build date and the engine pad stamp (L35 396) shows a November 19th engine build date.
This seems way too close??? Shouldn't the engine have a build date at least a month or so prior to the car?
Thanks in advance
It's a lot closer than my 08D L34, but I don't think that means much. Mine is:
7/23/69 Cast
7/28/69 Assembled
8/22/69 Final build
So a month between cast and final build date for mine.
-Dave
Semper Fi!
69 Camaro SS396 L34 X66
Old 12-17-2020, 04:24 PM
Thanks everyone for the info. Very helpful. My friend ended up buying the car.
Paul
'62 Bel Air 409/409
'68 L72 Biscayne
'69 L78 Nova
'17 Denali 3500HD
The Following User Says Thank You to SeattleCarGuy For This Useful Post:
HawkX66 (12-17-2020)
  #18
Old 12-17-2020, 05:07 PM
MN 70L78 MN 70L78 is offline
I know of a couple of cases on Norwood built Camaro's with big blocks where the car and engine were built during the same week. The engine could be at the Norwood plant 2 days after it was built. So very close dates on these doesn't surprise me. Usually there is a little more separation between engine and car build date but not always.
Scott Kiehne
70 SS L78 Camaro, born with drivetrain, 4:10's & M22, Classic Copper, Concours Restored.
70 SS L78 Camaro, Antique White w/Bright blue interior, 4:10's & M21.
Old 12-19-2020, 06:26 AM
roeville's Avatar
roeville roeville is offline
The block casting on my 1971 Z28 is A 19 1, the stamp is V0120, and my NCRS shipping report lists the production date: Jan 25, 1971. I’ve also talked to another 1971 Z28 owner built in January with similar dates.
Mike
