Old 12-24-2020, 09:48 PM
Default 69 Camaro Front Wiring Harness Question
I have 4 Red wires exiting the front lamp harness at the voltage regulator. One changes to Black and goes to the horn relay, one stays red and goes to the horn relay. One changes to Orange and goes to the voltage regulator. The other changes to Orange and I have no clue where it goes. Can anybody help?
Attachments - The Supercar Registry Screenshot (114).png Screenshot (113).png 20201224_161450.jpg 20201224_161421.jpg
Old 12-24-2020, 10:49 PM
https://ww2-secure.justanswer.com/up...iagramfull.jpg
Old 12-25-2020, 01:41 AM
Thanks Lee. I have an assembly manual with the wiring diagram. Still lost.
Old 12-25-2020, 03:02 AM
X66 714's Avatar
X66 714 X66 714 is online now
I can take a look tomorrow if nobody chimes in before...Joe
Old 12-25-2020, 01:08 PM
m22mike's Avatar
m22mike m22mike is offline
This may help ?
Old 12-25-2020, 04:30 PM
KevinW KevinW is offline
The rubber cyls are the fusible links. Inside that rubber is a smaller diam wire, that in the case of overload will melt inside the rubber. Not surprised the wire color is different on either side of the fusible links.
69 327 convertible (driver)
Old 12-29-2020, 03:30 PM
CLOSE but not quite the wire between the black cylinder and the terminal end is the fusible link.
I have collected the correct supplies over the years and replace burnt fusible links on any harnesses which I encounter -
The 12 gauge red wires RUN into 14 or 16 gauge fusible links.
The fusible link should be labeled on the wire - if it isn't I suspect the NEW link wire had metric sizes on them so they were removed.
The positive batt cable has a fusible link between the cable end and the junction on the rad support
Old 12-29-2020, 06:02 PM
HawkX66's Avatar
HawkX66 HawkX66 is offline
Do you have an ammeter gauge? I have the console gauges with ammeter. It matters... I believe the orange itself is a fusible link. My factory harness has one that loops right by the regulator between a red wire and a black wire with white tracer. I believe the same set up also goes across the radiator support and over to the junction block behind the battery if memory serves me right. It's the voltage variance across that wire that moves your ammeter, which incidentally isn't an ammeter. It measures a very small amount of voltage deviation. Mike's picture actually shows it pretty well if you can read a schematic.
-Dave
Semper Fi!
69 Camaro SS396 L34 X66
The Following User Says Thank You to HawkX66 For This Useful Post:
m22mike (12-29-2020)
Old 12-29-2020, 06:20 PM
I have idiot lights.
67 Camaro RS/SS 396 Original Drivetrain
70 Chevelle SS 396 Convertible Original Drivetrain
70 Chevelle SS 454 LS5 Survivor Original Drivetrain
70 El Camino SS 396 Original Drivetrain
65 Impala 396/425
65 Triumph TR4 Original Family Owned
Old 12-29-2020, 06:47 PM
X66 714's Avatar
That explains why mine didn't look like yours.....Joe
