I have 4 Red wires exiting the front lamp harness at the voltage regulator. One changes to Black and goes to the horn relay, one stays red and goes to the horn relay. One changes to Orange and goes to the voltage regulator. The other changes to Orange and I have no clue where it goes. Can anybody help?
Thanks Lee. I have an assembly manual with the wiring diagram. Still lost.
I can take a look tomorrow if nobody chimes in before...Joe
This may help ?
The rubber cyls are the fusible links. Inside that rubber is a smaller diam wire, that in the case of overload will melt inside the rubber. Not surprised the wire color is different on either side of the fusible links.
69 SS 350 convertible (in peices) 69 327 convertible (driver) |
![]() Quote:
I have collected the correct supplies over the years and replace burnt fusible links on any harnesses which I encounter - The 12 gauge red wires RUN into 14 or 16 gauge fusible links. The fusible link should be labeled on the wire - if it isn't I suspect the NEW link wire had metric sizes on them so they were removed. The positive batt cable has a fusible link between the cable end and the junction on the rad support
~JAG~ NCRS#65120 68 GTO HO 4 spd Alpine Blue /Parchment 2 owner car #21783 71 Corvette LT1 45k miles Orig paint - Brandshatch Green - National Top Flight - last known 71 LT1 built. 71 Corvette LT1 42k miles Original paint - Black - black leather - only black LT1 known to exist. NUMEROUS Lemans blue Camaros, Monza Red and Daytona Yellow Corvettes & a Chevelle or two... Survivors, restored cars, & other photos https://picasaweb.google.com/lh/myphotos |
![]() Quote:
-Dave Semper Fi! 69 Camaro SS396 L34 X66 Last edited by HawkX66; 12-29-2020 at 06:12 PM. |
The Following User Says Thank You to HawkX66 For This Useful Post: | ||
m22mike (12-29-2020) |
I have idiot lights.
67 RS/SS 396 Original Drivetrain 70 SS 396 Convertible Original Drivetrain 70 SS 454 LS5 Survivor Original Drivetrain 65 Impala 396/425 65 Triumph TR4 Original Family Owned |
That explains why mine didn't look like yours.....Joe
Thread Tools | |
Display Modes | |
