Old 03-06-2021, 03:02 AM
the427king's Avatar
Default Anyone ever see this?
Pic of rad. what is it? !
No Fisher priced toys here
Old 03-06-2021, 04:43 AM
Maxsg1973's Avatar
Maxsg1973 Maxsg1973 is offline
Either coolant gel from contamination, silicate breakdown/drop out, some iron corrosion or aluminum corrosion. Silicate dropout (white gel, goo or chunks) happens when the antifreeze/coolant has been used beyond it life expectancy and the additives break down. Mixing different types of coolants can make some weird gel byproducts too. Or possibly some form of stop leak. Flush it well and use good quality coolant with soft water or filtered water.
1968 Camaro SS L78 LeMans Blue original drivetrain
Old 03-06-2021, 11:58 AM
70 copo 70 copo is offline
If they are solid then a bad case of calcium depositing. This can be chemically flushed. Better put-a lime deposit.
Old 03-06-2021, 12:11 PM
Big Block 69 Big Block 69 is offline
I have seen plain water have soft clumps, but I have never seen antifreeze do that.
Old 03-06-2021, 02:16 PM
Zedder's Avatar
Zedder Zedder is offline
Looks like ice? Failed anti-freeze?
Mark
Old 03-06-2021, 02:49 PM
Burd's Avatar
Burd Burd is offline
I was in Pontiac at a salvage yard, they bottle used oil and coolant and sell it for a $1 a gal in milk jugs, Unreal.
It's only Orig once
waste all the rest.
1978 Y88
1995 Q45
Old 03-06-2021, 03:10 PM
Unreal Unreal is offline
For what purpose?
Old 03-06-2021, 05:02 PM
John Brown's Avatar
Every gallon a bone yard sells is one gallon that doesn't soak into the ground at their site, plus, they don't have to pay to have it disposed of.
Double, or maybe even a triple win on their part.
John Brown
Old 03-06-2021, 05:28 PM
Originally Posted by Unreal View Post
For what purpose?
To do whatever with - like add to or change your coolant. I used to see them all the time when I went to my local salvage yard. Beats $7 a gallon at Walmart. The ones I saw were all in at least what appeared to me as good condition. Nice green color with no sediments at the bottom of the container. Same for the Pink stuff. Here in NM we don't have a vehicle inspection requirement. So there are A LOT of beaters on the road. Never saw any used motor oil for sale though. I assume they drain that and sell it to the local guy who picks up used oil at places like Jiffy Lube.
Old 03-06-2021, 07:50 PM
the427king's Avatar
The oil in you car is the best place to cut corners to save 10.00. ? LOL
