Old 03-26-2021, 10:25 PM
danachevroletfor1967 danachevroletfor1967 is offline
Default Do I Need to Look into Getting New Wheels
I wanted to post this here so I could get feedback from you guys. When I last had my 1978 Camaro Z28, that I bought new, serviced they marked on the Courtesy Visual Inspection form that the lug nuts (original) were going on too far, going past where they're supposed to stop and would require attention soon. Is this most likely that they are just too old and should be replaced or is this more a wheel problem where the original 5 spoke steel wheels have the wheel stud holes enlarged now where the lug nuts instead of holding the wheel tight are actually being forced into the wheel stud holes too far? I know a buddy with a 1967 Nova SS had to replace his original steel wheels because the wheel stud holes were too large and he was told it was actually a safety factor.
Attachments - The Supercar Registry 100_0197.jpg 100_0196.jpg 100_0195.jpg 100_0194.jpg
Old 03-26-2021, 10:33 PM
The holes can get enlarged by repeated removal and install of the nuts, or by being left loose and allowing the wheel to slop around, but the BIG reason they get hogged out is over tightening by an impact gun. Steel wheels only need about 75 lbs ft of torque and many impacts can do double that with ease. If you have a friend with a torque wrench, have them try to tighten the nuts until the wrench clicks and read what it says.
danachevroletfor1967 (03-29-2021)
Old 03-27-2021, 12:03 AM
Totally agree , impact guns are usually set too high for my liking.
The Following User Says Thank You to chevelleheart For This Useful Post:
Old 03-27-2021, 09:06 PM
Thanks guys for the feedback. I'm sure the wheels have been taken off and put back on numerous times in 43 years, and I would bet always with an impact gun in putting them back on.
Old 03-27-2021, 10:03 PM
Get a few pics with the nuts on, so we can see how far out the holes have been flared and then with those same nuts off, to see how much space is around the stud. They may just be looking for business or protecting their butt from a lawsuit, IF something were to happen that involved the wheels. Businesses today can't be too careful with that kind of crap. Seems way too many people want to get rich from a frivolous lawsuit.
We all have steel wheels that have been off and on numerous times and they are still good. IF the nut goes past the wheel and bottoms on the drum/disc, THEN the wheel will be loose and could start wobbling and enlarging the holes.
Old 03-29-2021, 02:20 PM
x33rs x33rs is offline
They make cupped stainless steel washers just for that problem. I've had a set on my bird for a few years now and daily drive it with no problem. I didn't want to go through the trouble of finding more Pontiac Rallys and then the masking and painting process, so I tried the washers. Been fine since.
I forget where I bought them from but I did a search and lots of places pop up.
Here's one.
https://classicautoparts.com/hub-nut-washer
The Following 2 Users Say Thank You to x33rs For This Useful Post:
danachevroletfor1967 (03-29-2021), Xplantdad (03-29-2021)
Old 03-29-2021, 02:26 PM
rszmjt rszmjt is offline
Those factory wheels do require correct lug nuts, I have seen lots of lug nuts wear into and degrade the tapered section on the nut that seats against the wheel. On that note you can probably find after market chrome lug nuts with a 13/16 wrench head size which would have a larger tapered area where the nut contacts the wheel which may help.
The Following User Says Thank You to rszmjt For This Useful Post:
Old 03-29-2021, 06:20 PM
I don't think it is a major problem currently as by what I've been able to see just a few, not all, of the lug nuts have a splayed look to the chrome part of them against the wheel. I'll have to look further into it and will try to get some pics posted.
Thanks again.
The Following User Says Thank You to danachevroletfor1967 For This Useful Post:
Too Many Projects (03-29-2021)
Old 03-31-2021, 07:36 PM
Here are some pics I took showing some of the lug nuts that have that splayed look to them.
Old 03-31-2021, 07:56 PM
AnthonyS's Avatar
AnthonyS AnthonyS is offline
...would bulge nuts help here? Just throwing that out there. Cheers.
danachevroletfor1967 (04-01-2021)
