Old 04-15-2021, 03:13 AM
The important numbers!!
Name:  Alternator number.jpeg
Name:  block number.jpeg
Name:  carb number.jpeg
Name:  engine code stamp.jpeg
The Following 3 Users Say Thank You to Xplantdad For This Useful Post:
dykstra (04-15-2021), HawkX66 (04-30-2021), RPOLS3 (04-16-2021)
Old 04-15-2021, 03:14 AM
Here's a bunch of detail pictures...if you hover over the pictures, it will give you some info about the picture!
Name:  1a_The unique to early 66 picture frame shift boot.jpeg
Name:  1b_Tag and buckle on Hamill deluxe belt.jpeg
Name:  1d_LOF logo on the original tinted windshield.jpeg
Name:  1e_Proper 66 wiper arm, dull, shiny, then dull Trico blade holder with three rib blade.jpeg
Name:  1f_Original 3139 Holley carb.jpeg
Name:  2_Original dated plug wires with non-trademark R dist cap and 204 coil.jpeg
Name:  3_396 Chevelle only PS reservoir set up.jpeg
Name:  3a_unique to early '66 remote reservoir.jpeg
Name:  4_Early big block PS adjusting brace.jpeg
Name:  5_Air filter service sticker, also note circle S stamp.jpeg
Name:  6_Billet machined PCV valve.jpeg
Name:  7_lower radiator hose.jpeg
Name:  8_oil cannister.jpeg
Name:  8a_Small AC fuel pump.jpeg
Name:  9_Both sets of original keys with knock-outs intact .jpeg
Name:  11_Muncie M20 with shift linkage, backup switch and trans tag.jpeg
Name:  12_partial vin stamp.jpeg
Name:  13a_shift linkage.jpeg
The Following 4 Users Say Thank You to Xplantdad For This Useful Post:
60sStuff (05-13-2021), dykstra (04-15-2021), HawkX66 (04-30-2021), RPOLS3 (04-16-2021)
Here's more detail pictures...if you hover over the pictures, it will give you some info about the picture!
Name:  14a_Black painted hub and drum assembly.jpeg
Name:  16_Frame markings.jpeg
Name:  17_frame stamp.jpeg
Name:  18_Marking on RF frame horn.jpeg
Name:  19_underside front.jpeg
Name:  20_driveshaft showing stripes.jpeg
Name:  22_Gas tank blackout.jpeg
Name:  25_Spring with tags.jpeg
Name:  26_Orange paint on body bushing.jpeg
Name:  27_Paint runs on crossmember.jpeg
Name:  28_Paint runs on quarter panel rear pinch weld.jpeg
Name:  29_rear diff 1.jpeg
Name:  30_rear diff 2.jpeg
Name:  31_original trunk mat.jpeg
Name:  32_Original Goodyear Powercushion spare on 6 code whee.jpeg
The Following 7 Users Say Thank You to Xplantdad For This Useful Post:
60sStuff (05-13-2021), big gear head (04-15-2021), dykstra (04-15-2021), HawkX66 (04-30-2021), L78_Nova (04-15-2021), olredalert (02-27-2023), RPOLS3 (04-16-2021)
The all important docs!
Name:  tn_Body Broadcast sheet.jpeg
Name:  tn_Original Sales Invoice.jpeg
The Following 5 Users Say Thank You to Xplantdad For This Useful Post:
60sStuff (05-13-2021), HawkX66 (04-30-2021), olredalert (02-27-2023), RPOLS3 (04-16-2021), ScottG (01-30-2022)
Old 04-15-2021, 03:45 AM
"By The Numbers"
Name:  tn_By the numbers page 1.jpeg
Name:  tn_By the numbers page 2.jpeg
Name:  tn_By the numbers page 3.jpeg
Name:  tn_By the numbers page 4.jpeg
Name:  tn_By the numbers page 5.jpeg
Name:  tn_By the numbers page 6.jpeg
Old 04-15-2021, 03:48 AM
And the final picture, the original owner, Mr. John Hopkins!
Name:  Mr. John Hopkins..jpg
The Following 14 Users Say Thank You to Xplantdad For This Useful Post:
1967 4K (04-15-2021), 60sStuff (04-16-2021), big gear head (04-15-2021), dykstra (04-15-2021), HawkX66 (04-30-2021), L78_Nova (04-15-2021), L_e_e (04-16-2021), olredalert (02-27-2023), PeteLeathersac (04-15-2021), RPOLS3 (04-16-2021), ruralrte66 (04-16-2021), ScottG (01-04-2024), Tenney (04-15-2021), Woj (04-15-2021)
