#121
The assembly date and VIN on the trans will be on the flat pad (towards the tailhousing) across from the drain plug and where it says U.S. Patent. It is the flat pad where the mid-bearing plate is bolted up against.
Spray some carb or brake clean on it and the numbers should appear. - Warren |
#122
That's a casting number. The numbers you are looking for are on the axle tube, between the center carrier and the backing plate. They are usually on the side facing forward, but can be almost anywhere on that tube. They will be recessed from a hand held stamp, not raised as part of the casting.
Here's a pic of the assembly code you are looking for. ![]()
Mitch 1970 Chevelle SS 1966 Chevelle SS 1967 Camaro ss/rs 1938 Business coupe, street rod 2000 FXSTS, original owner, 13k miles Last edited by Too Many Projects; 04-19-2021 at 12:56 AM. |
The Following User Says Thank You to Too Many Projects For This Useful Post: | ||
PapsMaro (04-19-2021) |
#123
Just because you can turn one axle and the other one doesn't turn doesn't mean it's not positive traction. I've been telling people for more than 30 years that this is a completely unreliable way of testing a rear end. You will have to remove the cover to see what is in it. Look for a code stamped into the front of the right axle tube. The casting number that you posted is a common casting used for all Camaro and Nova 12 bolt rear ends that year. The stamped code will tell you what it is.
The Following User Says Thank You to big gear head For This Useful Post: | ||
#124
![]() Quote:
Yeah, Here is an example pic. I had the wrong side. ![]()
#125
Hope you are having some luck getting codes off the rear and bell housing.
Thread Tools | |
Display Modes | |
