Old 04-23-2021, 06:36 PM
WILMASBOYL78's Avatar
Post L78 Fuel....
Originally Posted by big gear head View Post
My 427 is a true 11:1 engine and I'm running 91 alcohol free fuel in it with the timing turned down to 35 degrees. When I go to the track I use 110 with the timing at 39 degrees. No problems so far. I have open chamber aluminum heads which may make a difference.
I would say those open chamber aluminum heads will definitely make a difference. Your actual compression is probably closer to 9:1 and aluminum allows for better cooling, so detonation isn't as much of an issue.
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
The Following User Says Thank You to WILMASBOYL78 For This Useful Post:
CanCOPO (04-23-2021)
  #12
Old 04-23-2021, 07:58 PM
I'm running open chamber pistons. I measured the combustion chamber volume, head gasket volume and piston dome with a piston deck height of about -.005 and did the math. It came out to 10.99:1, which is pretty much 11:1. The open chamber shape and aluminum material may help. I also probably have more valve overlap with my cam than what a stock L78 cam has, which would lower the cranking compression.
Old 04-23-2021, 09:02 PM
1971ls6's Avatar
1971ls6 1971ls6 is offline
With the alluminum heads it should run on 93
Old 04-23-2021, 10:35 PM
Post L78 Fuel....
Sounds like you have a nice setup on that motor...the cam duration will 'bleed off' some cylinder pressure and help the cause. What kind of HP does it produce??? Enjoy all this stuff now...with the way things are going, our hotrods will only exist in museums or magazines
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
Old 04-24-2021, 03:10 AM
Yea, limited time to enjoy them. It made 563 HP on the pump gas, but I didn't get any dyno time with race gas. 3600 pound car ran 10.85 at 125 with race gas, 11.17 at 123 on pump gas.
Old 04-24-2021, 04:07 AM
65blackcoupe 65blackcoupe is offline
I run half 110 racing fuel and half ethanol free gas. I never use regular ol pump gas of any grade. Ethanol free can be found at co ops, etc.
Old 04-26-2021, 12:17 PM
JRSully JRSully is offline
I use AV gas 100LL as well. I have a true 11:1 and the timing "all in" at 3k (timing is a big diff maker). I did put some 93 in it a few years ago, no good. Another advantage to AV100LL is it lasts a very long time without breaking down (ie: ethanol laced fuels), should you not use your car much. I get all I want at a local airport for $5 gallon, load up the jugs and leave them in the garage.
71 Porsche 911 Targa
Old 04-29-2021, 01:05 PM
Chevelle SS 396 L78 Chevelle SS 396 L78 is offline
Default 1967 L78 Engine Build Project...Design SCR?
I am in the process of organizing parts for my 1967 EG Block (L78) build for a Chevelle SS. I am on the fence as to whether proceed full steam ahead with a genuine parts correct (as close as possible) L78 build, or keep it as stock as possible only "lower" the design compression so it will easily run on pump gas (93 Octane). I've talked with owners who swear their L78's run fine on 93 without detonation, and others say "don't do it!" So, I'm conflicted as to what to do. I just did a compression calculation with my assumed parts and gasket/deck thicknesses and calculated 10.8:1 SCR.
I want to build a correct cone (starting with a true 138 car Chevelle), but paint it and trim it out to match my original 1967 Chevelle SS 396 L78 car (very rare and long gone!) I've been looking for it for more years than I can remember! So, the L78 in '67 was the same engine in both the Camaro and the Chevelle.
Has anyone been successful building their engine with lower compression (say 9.0:1 and how did it run? I want to "re-live" my youth in a clone of the car I "still remember" how powerful and fast it was back in the day! If it;s going to run like a "dog" instead of a "scalded dog" due to low compression, I don't want to throw money at this project at this point in my life. But, if it will run the same or very close?...I'm all in. 4.10 Posi, Muncie M20 4-speed. I was also thinking of shooting for maybe 10.2 to 10.5 compression.
Any advice would be very much appreciated! Thanks! John
The Following 2 Users Say Thank You to Chevelle SS 396 L78 For This Useful Post:
L72Chevelle (04-29-2021), scuncio (04-29-2021)
  #19
Old 04-29-2021, 02:18 PM
You could just put thicker head gaskets on it. Cometic makes many different thickness gaskets. That may make enough difference.
Old 04-29-2021, 03:55 PM
----Build the engine you really want and find some place that sells 91 octane non ethanol. Then spend the bucks to get 110 in five gallon cans and add 5 gallons to the 91. You will be happy with the outcome.....Bill S
RPOLS3 (04-29-2021)
