Old 05-13-2021, 06:18 PM
I think the only way you'd fit an L60 on a 69 is by perhaps trying to fit them in there using 7" wheels. Even then you'd probably still need rolled lips to make them work other wise they likely rub on a 69. On my green car, I had at one point set it up with Pro Trac L60's on 8" Cragar's and it still needed air shocks or they'd rub. Eventually went stock with that car but learned a little from the mockup.
I want to try dropping the back down on this one and utilize the air bags, and that means a smaller tire being in there. Not that I won't switch it around every once in a while. Air bags only take 30 minutes to remove and install so no big deal to remove them if I want to air up the shocks and mount the N50s.
Chuck_Burg (05-13-2021)
