1969 Camaro Hurst Shifter Assembly
Pulled from a purchased transmission. I do not know the history and all I did was clean it up. $700 shipped lower 48. It’s not perfect it’s 90% complete (minus the isolators, clips and reverse lever).
GLWS. Nice setup
69 SS/RS 396 M20 X22 Nor 12B,72B,712 bought 1979 FULL OWNER HISTORY 69 Dick Harrell tribute Day II 427 M20 4.10 X11 76 orig pnt, 711 67 Super Stock 302 Camaro re-creation |
There are no numbers on the rods and I wanna make sure everyone saw the weld repair on the on rod which a grinder and some time you would never know it was welded.
Went ahead and smoothed out the weld before going on eBay. Last edited by cook_dw; 06-02-2021 at 12:15 PM. |
In case you are not aware, that is not a '69 Camaro reverse lever.
- Warren |
The Following User Says Thank You to WorkinProgress For This Useful Post: | ||
cook_dw (05-30-2021) |
The levers are just included. I should have made that known in the original post.
The reverse lever is 68 Firebird. I imagine that is what the shifter came out of. Nice piece.
Jason |
The Following User Says Thank You to SuperNovaSS For This Useful Post: | ||
cook_dw (06-02-2021) |
Transmission was 68 Firebird from the partial vin. Learned something today. Thanks Jason. Didn’t know 68 Firebirds had the same shifter assembly as 69 Camaro.
EDIT 6/2/21: Wanted to add that I just discovered that the shifter handle will need knew clips and isolators. Around $40 from Camaro Central. Thought I should disclose the findings as soon as I found it. New price due to this and the weld issue. $700 shipped lower 48. Also added a photo in my previous post of how the welded 1-2 rod cleaned up. Last edited by cook_dw; 06-02-2021 at 03:20 PM. |
PM sent
Less than 4 hours left on eBay.
Thread Tools | |
Display Modes | |
