Old 07-22-2021, 05:39 PM
tater223 tater223 is offline
Default Cragar Rims on 68 Camaro
Just finished the rebuild on my 427 and looking to swap out these 90's Weld wheels for some Cragars. I have looked long enough for round spokes with no success so I am just going to order some flat spokes for the front. Torn between 15x4.5 or the 15x6 for the front. Issue is...I have 4 piston calipers and backspacing is an issue. If you are running Cragars on less than a 7" rim, what is your combo of backspace and spacer? Really dont want to swap to single piston.
Attachments - The Supercar Registry IMG_20210724_064937778_HDR.jpg IMG_20210724_064910969.jpg IMG_20210724_064853099.jpg IMG_20210724_064834070_HDR.jpg
Old 07-22-2021, 07:08 PM
1967 4K's Avatar
1967 4K 1967 4K is online now
Default Cragar on front
I have Cragar SS 15x4 round spoke and have two piston disc on the front of my 67. I used a 1/2 inch spacer but could have got by with a 3/8. You have to use extra long shank Mag lug nuts and cut them down to the proper length. I drilled my spacer out to the size of the nut shank did as to let the shank set deeper on the lug bolt. Left about a 1/16 to play on.
We have a machine shop at work and those guys help me figure out all length measurements and it didn’t cost me anything. They used a mill to cut them and used a tap to clean up the threads.
I installed them a torqued them to 100 foot lbs. and they never came loose. Doing it this way you don’t have to change out the lug bolts to longer one like most racers use. I can go back to the stock steel wheel and all is as factory correct.
Richard
Richard
1967 Camaro SS 396/375 4K
Old 07-22-2021, 10:42 PM
GrumpyJeff's Avatar
GrumpyJeff GrumpyJeff is offline
I have original 15x4's on the front of my 67 which has 4 piston Baer brakes, No fitment issues or spacers needed. And do your self a favor, keep looking for original round spokes, You wont be happy with the newer version !!!
Old 07-22-2021, 11:53 PM
I will keep looking for round spokes, but I need to get rid of these rims on the car now which are old Weldwheels by Cragar. I was hoping to get away without spacers in the front, but it does not sound like it is possible with these factory calipers.
Old 07-23-2021, 02:31 AM
Tommy Tommy is offline
This isn't a great picture but I bought a set of new direct drill cragars for the Nova. 15x4 1/2 & 15x7. Only a handful of people would know the difference between these and a 50 yr old cragars other than the rust on the old ones. I have original round spoke on another car. I like these alot too though.
Tommy
The Following 8 Users Say Thank You to Tommy For This Useful Post:
68 Chevy II (07-23-2021), big gear head (09-03-2021), Damien (08-03-2021), dykstra (07-23-2021), L78_Nova (07-23-2021), L_e_e (07-23-2021), napa68 (07-23-2021), scuncio (07-23-2021)
Old 07-23-2021, 03:57 PM
Thats a good looking nova Tommy. Those wheels look great too!
Old 07-23-2021, 07:14 PM
mnyenko mnyenko is offline
What size tires are you using? Are they pro trac? Thanks Earl
Old 07-23-2021, 07:50 PM
Zedder's Avatar
Zedder Zedder is offline
Come on Tommy…we need more pics! Looks awesome!
Mark
Old 07-23-2021, 09:48 PM
The front appear to be Firestone pie crusts from Coker and size looks like 6.40.15. The rears almost look like drag radials but I'd say those are M&H from the looks of them. Definitely not Pro Tracs.
Old 07-24-2021, 12:02 PM
The fronts are Coker 6.40-15. a Firestone deluxe champion. The rear are M&H J60-15. Here's a pic with the engine installed. It brought the front down where it should be.
68 Chevy II (07-24-2021), big gear head (09-03-2021), Damien (08-03-2021), dykstra (07-26-2021), mnyenko (07-24-2021), NorCam (07-24-2021), RPOLS3 (09-02-2021), Xplantdad (07-25-2021)
