Old 10-17-2021, 09:40 PM
solospeedshop solospeedshop is offline
Default Rare Camaro History
Solo Smokey Update Okay found some super cool Camaro history!
Rumor has it that Chevrolet came out with a 3x2 manifold for Trans Am Racing and then the project was scrapped. They were working on this before the first 67 Camaro was made Well I can now document this I pulled off the manifold on my 69 Z28 that previous owner Larry Schreib bought it off of Smokey Yunick himself I flipped over the manifold and could not believe it is dated 2/9 /66 it's all true case solved! Thanks in advance Bill Fowler / Solo Speed Shop
The Following 13 Users Say Thank You to solospeedshop For This Useful Post:
1967Z28 (10-17-2021), 60sStuff (10-18-2021), dykstra (10-19-2021), John Brown (10-17-2021), L_e_e (10-17-2021), olredalert (10-18-2021), PeteLeathersac (10-18-2021), SS427 (10-18-2021), Steve Shauger (10-17-2021), Tenney (10-18-2021), Tracker1 (10-17-2021), Xplantdad (10-18-2021), YenkoYS-199Stinger (10-18-2021)
Attachments - The Supercar Registry IMG_1446.jpg IMG_1445.jpg IMG_1444.jpg IMG_1443.jpg
Old 10-17-2021, 11:29 PM
6t7 camaro 6t7 camaro is offline
That is way cool! I had read about those somewhere and had always wondered if any/how many had been made. Thanks for sharing!
Old 10-17-2021, 11:37 PM
1967Z28's Avatar
1967Z28 1967Z28 is offline
While you have the manifold off it is a good time to clean it, but don't beadblast it.
Old 10-17-2021, 11:43 PM
I mentioned Dry Ice blasting on Facebook....
Old 10-18-2021, 12:31 AM
That is really cool. Thanks for sharing. I use plastic media frequently to clean parts like this. It take off the dirt and surface corrosion without altering the finish.
Jason
Old 10-18-2021, 01:26 AM
Vapor blasting is the way to go these days. David Beem is a site sponsor here and has the latest apparatus setup for proper cleanup.
You can contact him through his bodyshop I think? https://fixautousa.com/location/colorado-springs/
Old 10-18-2021, 02:30 AM
Why would they use a 3X2 setup for Trans Am Racing instead of 2X4?
Old 10-18-2021, 11:45 AM
William William is offline
They didn't.
The 3 x 2 manifold was never released to production and is not listed in the SCCA T/A Homologation documents for the Z/28.
Old 10-18-2021, 02:29 PM
John Brown's Avatar
Just because it wasn't used doesn't mean it wasn't under consideration. Engineers try things to see what works best. The 3x2's must not have come out on top.
Personally, I used to run two 650 cfm Holley two barrels on a cross ram manifold in an IHRA drag class because the class record was softer than it was with a single four barrel. Rule books were meant to be read, whether it's Trans Am or drag racing.
John Brown
Old 10-18-2021, 02:33 PM
ELEFUNTMAN ELEFUNTMAN is offline
Nice rocker arms and headers too!!
