Old 10-26-2021, 12:07 AM
SS427's Avatar
SS427 SS427 is offline
Perfect Charley. Interesting that they were not using flanged exhaust bolts.
Rick Nelson
Old 10-26-2021, 02:47 PM
Rick:
Isn't it SOP to have a washer under the bolt for aluminum engine parts to prevent galling when tightened?
SS427 (10-26-2021)
  #23
Old 10-26-2021, 03:21 PM
SS427's Avatar
Rick:
Exactly why I was asking.
Rick Nelson
Old 10-26-2021, 03:35 PM
x33rs x33rs is offline
That seems to vary sometimes. Not to steer off subject but when it comes to aluminum intakes, I think the BBC used washers under the bolts from originals I've seen, but some SBC aluminum intakes didn't.
I know the 69Z's did not use washers under the bolts on the intakes.
Doesn't really make a lot of sense but that's what I've observed. Different assembly plants I know, but bolts gulling up aluminum you would think would want washers as kind of a standard procedure across the board.
Old 10-26-2021, 03:38 PM
Rick: when did Chevrolet stop this method of attaching the exhaust headers to the heads?
Old 10-26-2021, 03:48 PM
SS427's Avatar
That is correct, the BB engines (at least in 69/70 used a washer headed bolt other than where the engine lift bracket was bolted to just like in Charley's photo.
Rick Nelson
Old 10-26-2021, 03:53 PM
SS427's Avatar
Please don't quote me as I do not study the early cars but I think possibly 1966?
Rick Nelson
The Following User Says Thank You to SS427 For This Useful Post:
Lee Stewart (10-26-2021)
  #28
Old 10-28-2021, 01:47 PM
MosportGreen66's Avatar
Rick, do you know if washers under head bolts is also correct for L89 Corvettes? I don't recall if our car had them? I'll need to study up on the NCRS manual too
Old 10-28-2021, 02:12 PM
SS427's Avatar
Based on the little research that I have done for this L89 I would say yes, they should have washers and would assume an L88 would as well.
Rick Nelson
