Old 12-11-2021, 02:28 PM
Ralph Spears's Avatar
Default Help to ID 1964-65 Muncie 4 speed
There is no VIN but main case is casting # 3851325 Tag on side cover#3780800 is it close or wide ratio
Old 12-11-2021, 04:06 PM
Ralph,1 ring on the input shift is close 2.20 ratio. 2 rings is wide 2.56 ratio. No rings is m22 on the Muncie factory input shafts.
Old 12-11-2021, 04:55 PM
MarcDant's Avatar
MarcDant MarcDant is offline
I have a 64 input shaft with 24 teeth with no rings (wide ratio) , the tag that was removed from same tranny that reads 3841435 if i remember correctly was a 3.36 rear ratio. Maybe some one can confirm .
Old 12-11-2021, 06:01 PM
The 3780 beginning part number does not make sense for a 64 or 65 Muncie trans. 3780 correlates to part numbers originally issued in about 1960 or 1961. Numbers of course can continue to be used for years, but since Muncie's did not first exist until 1963 that would not be the case here. For example, the part number listed in the AIM for a 1964 Chevelle Muncie (wide ratio) is 3841435.
So the tag probably does not go with that trans.
You can at least narrow down the maincase to being original to either a 64 or a 65 trans. 64 maincases have a smaller rounded casting boss on the top rear center of the case (where it is drilled and tapped for the hole for the top center tail housing bolt). 65's have a much larger rectangular boss which looks like 66 and later cases.
Jeff Helms
65 Z16 Survivor
65 Z16 drag car
66 Chevelle L78 unrestored
67 Chevelle L78 unrestored
67 Camaro SS350 Survivor
Old 12-11-2021, 09:43 PM
John Brown's Avatar
Early Muncies don't follow the same rules as later ones do. I also had a wide ratio 2.56 (325 case) with no grooves on the input.
John Brown
Old 12-11-2021, 10:53 PM
Thanks, do you know when they started using the rings?
Old 12-11-2021, 11:11 PM
Looks like 63 through 65 had no groove on the m20 and 1 groove on the m21. I did not know that.
Old 12-25-2021, 03:56 PM
crash crash is online now
The rounded casting boss change over was the middle of Dec. of 1964, well into 1965 production.
I have found several articles stating what Jeff posted, but I check over 100 325 cases and could not find a rectangular boss until late Dec. of the 1964 calendar year, which is 1965 production year
Hope this helps... Crash
Old 12-25-2021, 11:07 PM
I found out it is a wide ratio
The Following User Says Thank You to Ralph Spears For This Useful Post:
Jimlt4383 (12-26-2021)
Old 12-27-2021, 10:42 PM
TAR6569 TAR6569 is offline
Ralph, is the date code stamped in the 64 location by where the side cover mounts? Also, is there a partial vin starting with a T stamped on the edge of the tailhousing where it mounts to mid plate?
381 and counting in the 67-69 Impala SS427 registry
