Old 04-18-2017, 01:21 PM
The "domes" can easily be ground off on a bench grinder with a coarse stone.
Assuming all else is correct (size) they should work fine with the fingered brackets.
Old 04-19-2017, 07:33 AM
ZLP955's Avatar
ZLP955 ZLP955 is offline
Try these, at least the description sounds like they are correct for the tab/finger style:
https://www.camarocentral.com/1967_1..._p/sus-474.htm
Tim in NSW, Australia
Old 04-19-2017, 11:29 AM
cwc's Avatar
cwc cwc is offline
I ordered these for a customer a week or so ago for his 69 Z,they are too small also.they will not work with the brackets with the side tabs.they are just like the ones I ordered through Napa, they even had same part number casting.
1967 SS427 4 speed triple black survivor-sold to a good home
1969 nova SS396 L78 4 speed triple black survivor
1970 camaro SS350 citrus green,Dad bought it new!
1968 chevelle ss396 L34 M21 KK rear all born with
1972 formula 400 M22
Old 04-20-2017, 02:19 AM
ZLP955's Avatar
OK, thanks for pointing that out. Have you been able to find an alternative for your customer yet?
Old 01-13-2022, 01:15 AM
https://www.camarocentral.com/1967_1..._p/sus-398.htm
I have 6 of the ROUND Rubber Bushings that fit the 11/16 sway bar and the above clamps...
Wanting to determine value and who reproduces them ????
Mine have no embossed or printed codes/numbers
I also have the ORIGINAL 11/16 front sway from the #27 ZL-1
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Old 01-13-2022, 02:50 PM
KevinW KevinW is offline
I now see the issue here.
The domed repro bushing matches the exterior dimensions as the original, so no issues there and can be used as is.
But the repro tabbed versions are not as wide as the originals, so they do not fit properly between the tabs and slide around.
Maybe get 2 sets of the tabbed bushings and use two per side! Cut them so they fit between the tabs. You won't see the parting line when installed. My .02
As to the suggestion about grinding the domes off, good idea, but since the domed repros are pretty much the same size as the repro tabbed ones, they too will slide around. (Sorry Lynn )
One question, does anyone know when the change over in styles happened? I assume domed is early and tabbed is late?
69 327 convertible (driver)
The Following User Says Thank You to KevinW For This Useful Post:
PeteLeathersac (01-13-2022)
