Old 01-30-2022, 11:52 AM
R68GTO R68GTO is offline
Default Mallory Rev Pol system
I've accumulated this group of parts with the intention of putting it on my COPO. I want to confirm if these parts all work together (I think they do), and if anyone has a wiring schematic so I know I'm hooking everything up ok. Any tips/advice/thoughts?
Attachments - The Supercar Registry s-l64.jpg IMG_2511.jpg IMG_2510.jpg IMG_2509.jpg
Old 01-30-2022, 12:50 PM
cook_dw's Avatar
cook_dw cook_dw is offline
You will need a rev Pol distributor to be technically correct but it appears they setup that 310 to potentially work as a rev. The YC310 is the standard distributor. I have a rev Pol distributor in the garage that I need to restore.
Read through this thread to see if it helps any.
https://www.jalopyjournal.com/forum/...estion.111336/
Old 01-30-2022, 04:04 PM
Thanks for the link Darrell. Are you referring to the jumper wire between the two condensers as the modification to make it work like a Rev Pol? The SuperMag transformer has another terminal under that red cap, is that used when you need a double coil?
Old 01-30-2022, 03:01 PM
The Rev Pol coil was unique as well Jim, but no reason you can't hook all that up and run it as you have it. Just not sure the light/switch will connect or function with that coil. PM me with your email and I'll send you the Rev Pol instructions.
I have a few wiring schematics I can send.
Old 01-30-2022, 04:16 PM
cook_dw's Avatar
Condensers are separate on rev. Cam plates are also a little different but again you can run that distributor with rewiring. norcam is correct you need a rev Pol coil. Super mag is for a magneto. I have a couple coils but not worth using.
Old 01-30-2022, 04:29 PM
One of these?
Old 01-30-2022, 04:46 PM
I believe this is the coil you need for the Rev Pol system. I'll be happy to sell you this one.
Jason
cook_dw (01-30-2022)
