Old 02-04-2022, 03:35 AM
67since67's Avatar
Originally Posted by Jonesy View Post
Hopefully you can find that front passenger side trim for the wood and deck this thing out in wood again.
Nice base to work with here
Got that covered, I have trim from two other cars stashed upstairs.
The Following 3 Users Say Thank You to 67since67 For This Useful Post:
60sStuff (02-05-2022), Jonesy (02-04-2022), olredalert (02-04-2022)
  #62
Old 02-04-2022, 03:57 AM
67since67's Avatar
Originally Posted by 60sStuff View Post
Bill,
What can I say, besides I’m late to this long top party.
There is so much to cover on this Yenko site that I completely missed your thread on this Awesome ‘67 wagon.
Boy I love Red interiors on 60’s cars.
I also have a stash of excellent Survivor quality GTO items from 40+ years that comes in handy, such as your spare dash that this wagon needed.
I seem to like the same types of cars that you like (patina here, cracking over there and a few rub through in spots), which is typically on a Survivor car. You can’t duplicate that.
Do I see 97K plus on the odometer?
Fremont built cars (64-67+) had the TT / Data Plate crudely masked off which yours shows. I’ve seen a few BF cars that were painted black but the majority were taped off.
You did good on the orange fogged water pump and brake fluid drippings.
Inner fender skirts look awesome after cleaning.
Fremont bumper jack bases are a rectangular black painted version, whereas the back east (Pontiac cars) plants typically used a square blue painted base.
There are so many products available for cleaning and detailing our Survivor cars, but a couple I’ve used since the 70’s is “never dull” and “bronze wool”.
Love the license plate frames with the black & yellows.
The full tint glass all windows, which is recommended with AC cars looks nice with the white body.
This summer, turn on that air condition in that beautiful red interior and head out.
I’ll be following this thread now.
Chris.
Better late than never Chris!
I am also a big fan of 60's red interiors especially in white cars.
Odometer shows 07722.0, so rolled over. The L30 runs amazingly well, smooth and quiet, no smoke, added one quart to drive from CA. I see nothing to indicate the heads have ever been off (French locks are still in place!) but I'm sure the timing chain has been replaced.
As you noted, masking of the TT was strictly a Fremont thing on for a '67 Chevelle.
Fremont jacks, have you observed any predominance of either the tube or the tee style shafts?
Follow along as I take this project over the hump.
60sStuff (02-04-2022), olredalert (02-04-2022), PeteLeathersac (02-05-2022)
  #63
Old 02-05-2022, 04:22 AM
67since67's Avatar
Time to wipe the ugly off this ride!
Bumpers, and front sheet metal removed. CAREFULLY removed all that 60 plus feet of body side moldings, tailgate trim and emblems. I do not have a spare of the tailgate "Concours" emblem, and the attaching barrel clips did not want to let go! I spent an hour finessing it off, thinking it would surely break!
I removed the door panels, necessary to remove the door handles and also to salvage the unique side molding clips. I tried to source all new clips but the pictured rectangular plastic clips were not to be found.
With the door panels off I cleaned and lubed window regulators and door latches etc.
As previously mentioned, the RF fender had been replaced with a used and painted white. Strangely, this fender must have came from a cheapo 300 series as it had no holes other than for antenna, not even an engine call-out.
Using trim from my stash and measurements from the other fender the appropriate hole were drilled.
Also, the fender paint had some peeling on the inner under hood jamb, so that was prepped and painted.
The Following 5 Users Say Thank You to 67since67 For This Useful Post:
60sStuff (02-05-2022), Dave Rifkin (02-05-2022), dykstra (03-06-2022), L78_Nova (02-06-2022), PeteLeathersac (02-05-2022)
  #64
Old 02-05-2022, 04:33 AM
67since67's Avatar
I've had this MBX rubber wheel vinyl removal tool for many years, but it did not work well here. What remained of the original vinyl was mostly dried up adhesive and the bottom layer of the vinyl film.
After trying several removers, chemicals etc, I resorted to oven cleaner and a single edge razor blade on a handle. This actually worked pretty well but still a tedious task!
First application removed most of it, followed by another to remove leftovers. Then a wipe down with denatured alcohol.
60sStuff (02-05-2022), Dave Rifkin (02-05-2022), dykstra (03-06-2022), grantprix (02-23-2022), olredalert (02-05-2022)
  #65
Old 02-05-2022, 04:39 AM
67since67's Avatar
The area behind the gas door is painted brown to prevent a body color outline breaking up the woodgrain.
The Following 4 Users Say Thank You to 67since67 For This Useful Post:
60sStuff (02-05-2022), dykstra (03-06-2022), grantprix (02-23-2022), L78_Nova (02-06-2022)
  #66
Old 02-05-2022, 04:54 AM
67since67's Avatar
With wagon all naked and embarrassed it's time to bring life back the the chalked out paint.
First a color sand with 1,000 grit, then 1,500, 2,500, 3,000, and finally 5,000.
Next Presta 2step, applied with a buffer, followed by Collinite 845 applied by hand,
The woodgrain areas were sanded with 220.
Now it's ready for woodgrain!!
The Following 12 Users Say Thank You to 67since67 For This Useful Post:
1967Z28 (02-05-2022), 60sStuff (02-05-2022), 69M22Z (02-05-2022), carnut4life (02-06-2022), Crush (02-05-2022), Dave Rifkin (02-05-2022), dykstra (03-06-2022), grantprix (02-23-2022), L78_Nova (02-06-2022), olredalert (02-05-2022), PeteLeathersac (02-05-2022), RPOLS3 (02-05-2022)
  #67
Old 02-05-2022, 12:35 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
Wow - what a transformation.
Jake Dykstra
Dykstra Motorsports
67since67 (02-05-2022)
  #68
Old 02-05-2022, 02:06 PM
----Wow, just Wow, Bill! I would never have imagined this. Very cool!.....Bill S
  #69
Old 02-05-2022, 03:02 PM
60sStuff's Avatar
60sStuff 60sStuff is offline
Geezzz Bill,
Where do you find the energy? Must be love of an old car.
I’m impressed
  #70
Old 02-05-2022, 03:50 PM
TimG TimG is offline
You’re amazing, Bill. Components that look hopeless turn out very nice with the proper cleaning. You’re just applying this theory to the entire car.
You must have a nice heated garage.
