The CRG has a really good report on shifters, linkage and knobs. The correct knob is stated to be 2-piece black and chrome with shift pattern.
Here's the link: http://www.camaros.org/shifters.shtml The '67 AIM shows the 2-piece knob but doesn't specifically include the L78. It may be that the knob revision of 3-10-67 was prior to L78 production. The '68 AIM show the 2-piece knob and states "12000 EXC. PROD V8 ENG & RPO L30-L48" in the title block. I believe this includes all big blocks. |
This is the Muncie handle and GM 2-piece knob that will be installed in my 67 Z. There is a "G" molded into the top half of the ball.
Thanks Terry for the info.
Richard 1967 Camaro SS 396/375 4K 2002 Camaro 35 Anniversay Z4C-WU8 |
![]() Quote:
My cars build date is 06A so I’d say the two piece would be correct for it.
Thanks all.
Thanks for the confirmation, I wasn’t sure how to interpret the shifter knob revision notes in the AIM. I’ve got a 01D L30 M20 car that will need it’s knob swapped out to a 1 piece.
Hi speed passes with fast shifting weaken the threads.
I agree. The lower knob was added to the AIM in March in 3 illustrations.
But it's confusing - 3895201 was replaced, but by the same number. 3895201 and 3895202 were in the early parts manuals, and then 3895201 was used with the 2-piece system. My question is: if the early knobs were one piece, how did they lock them into the right orientation for the shift pattern?
Kurt S - CRG |
I’ll add a little more to the subject. Was the 69 black 4 speed two piece the same as the 67-68 except tapped 3/8 inch for a Hurst shifter?
Thanks
I believe they are the same except for thread size. Here's the 3/8-16 knob that came on the transplanted Hurst shifter in our 67 Camaro.
Thread Tools | |
Display Modes | |
