Old 02-18-2022, 02:27 AM
1969camarors427's Avatar
1969camarors427 1969camarors427 is offline
Default 1969 Chevrolet AM/FM Stereo Blue Light Radio/Multiplex Amp Camaro Chevelle
1969 AM/FM Blue Light Stereo Radio with Multiplex Amp. Can be used in 1969 Camaro Chevelle Nova and Impala. Now $625.00 USD
The cable between the amp and radio is 18" long as seen in pictures. I am not sure of the correct length for each model, Camaro is a long cable as it mounts behind the glove box. If you know the Camaro length let me know and I will add to description.
The radio number is 7307331 and model number is 91BFM2.
The amplifier number is 7308261 and model number 61SSA-4 and a few other numbers but the tag is partially missing.
Looks to have been serviced at one time as there is a sticker from Mollen Brothers Auto Sound Systems from Richmond VA on it.
I have put 12V to the radio and hooked up one speaker (all I have). The radio backlight comes on and the FM stations come in good, I do not have a antenna so I can not test the AM channels but it switches to AM and there is just static noise as you need a antenna for AM stations.
I tested the output on all speakers wiring by attaching the speaker to each of the speaker wires from the 6 pin connector and each curcuit has speaker output.
The amp does not have the bracket that mounts the amp behind the glove box. Looks easy enough to fabricate.
I am also including a radio noise suppressor for use with FM radios that goes as a jumper on the heater fan power wire.
Please look at all pictures to see condition of the radio. I would put a new lens, available reproduction, as there are small lines on the lens from the outside of the lens going inward as seen in the pictures.
Both the radio and amp cases are in very nice rust free shape. The radio knobs look new.
I am selling this in a as is condition. But as I stated above the FM does work.
625.00 usd
Shipping from Calgary Alberta Canada.
Accept PP F&F Thanks
Attachments - The Supercar Registry 20220219_105901_resized.jpg 20220219_105849_resized.jpg 20220219_105845_resized.jpg 20220217_164024_resized (2).jpg
