Old 03-01-2022, 11:56 AM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
Originally Posted by napa68 View Post
Make any progress Jake?
Not on the brakes - thanks for asking. I tried smashing the pedal several times on Sunday with no luck so instead I started cleaning the car up since it has been sitting for 18 months. Adjusted the hood latch, did some paint touch ups, installed a correct alternator/smog pump belt from Quanta, washed the car cover. Haven't given up yet, just trying to be productive in other areas.
Jake Dykstra
Dykstra Motorsports
napa68 (03-01-2022)
  #102
Old 03-01-2022, 02:39 PM
67since67's Avatar
Good move Jake! Countless times I've fought with something, walked away for a while, came back and it fell into place. Hopefully the case here!
RPOLS3 (03-01-2022)
  #103
Old 03-01-2022, 07:49 PM
----Yup, Bill! That's my mantra. Walk away and settle down. Don't sweat the small stuff, and it's almost all small stuff!......Bill S
The Following 4 Users Say Thank You to olredalert For This Useful Post:
Big Block Bill (03-02-2022), dykstra (03-01-2022), RPOLS3 (03-01-2022), Xplantdad (03-01-2022)
  #104
Old 03-02-2022, 04:29 PM
RPOLS3's Avatar
I bought this tool and I'm told it should will re-center the valve in the casting without needing to remove the casting from the frame, just remove the pressure switch (may be harder than it sounds) and screw this in its place. Once valve is centered I think you can leave it in while bleeding to make sure it does not move due to pressure differences while bleeding.
I would have thought you would need to use a small screwdriver or pick to move the valve prior to inserting this but maybe not?
Jake Dykstra
Dykstra Motorsports
The Following 2 Users Say Thank You to RPOLS3 For This Useful Post:
dykstra (03-03-2022), L_e_e (03-07-2022)
  #105
Old 03-02-2022, 08:38 PM
napa68 napa68 is offline
I believe the piston is tapered inside.
Old 03-02-2022, 09:44 PM
daverd daverd is offline
Who rebuilt your valve?
2017 impala (wife’s car)
Old 03-02-2022, 09:47 PM
RPOLS3's Avatar
Karp's
Jake Dykstra
Dykstra Motorsports
Old 03-02-2022, 09:48 PM
RPOLS3's Avatar
So the tool should self center when screwed in due to the taper?
Jake Dykstra
Dykstra Motorsports
napa68 (03-04-2022)
  #109
Old 03-02-2022, 10:24 PM
Hopefully...
I would put a mild radius on the very end, so it isn't such a sharp edge.
Yes, leave it in until done bleeding.
RPOLS3 (03-03-2022)
  #110
Old 03-04-2022, 01:41 AM
Yes
RPOLS3 (03-04-2022)
