Go Back   The Supercar Registry > Sponsors > Boulder Motorcar
Old 04-08-2022, 06:04 PM
WOW, the floor pan looks clean enough to eat off of..
That is a great pic of the oval tail pipes. I needed that as a reference for the Pypes set I have. There is no way I can ever get them to stop rattling on the body or spring. I'm gonna make a wooden buck and shape them in my press. I knew the last several inches of those pipes were pressed from the factory, but that is a perfect example.
I would be welding the pin holes in the exhaust pipes, unless you have a set coming from Eric..
Old 04-08-2022, 06:51 PM
napa68 napa68 is offline
I have had these Cragar's laying around I bought from a couple of forum members thinking this day may come. And yes, I know the front tires are waaay too large.
So..........TT's or Cragar's?
The Following 2 Users Say Thank You to napa68 For This Useful Post:
Stihl (06-12-2024), YenkoYS-199Stinger (04-11-2022)
  #213
Old 04-08-2022, 07:02 PM
67since67's Avatar
Personally Tim, I think TT's are a better choice with that color of that killer Camaro. - Bill W
(I like that yellow Seville in the background too!)
The Following 2 Users Say Thank You to 67since67 For This Useful Post:
L78_Nova (04-11-2022), napa68 (04-08-2022)
  #214
Old 04-08-2022, 07:04 PM
Donnie's Avatar
Donnie Donnie is offline
TT
69 SS L78 Chevelle
70 SS 396 Chevelle
The Following User Says Thank You to Donnie For This Useful Post:
napa68 (04-09-2022)
  #215
Old 04-08-2022, 07:13 PM
TimG TimG is offline
TT gets my vote, too.
napa68 (04-09-2022)
  #216
Old 04-08-2022, 07:18 PM
dykstra's Avatar
dykstra dykstra is offline
TT
Dave Dykstra
NCRS#66003
you. – Jeremy Clarkson.
Dykstra Motorsports
napa68 (04-09-2022)
  #217
Old 04-08-2022, 07:26 PM
60k miles, original paint........killer underbody with it's window sticker. I bought that and a 76 Eldorado with 34k miles and a ton or original paint too. That's what I should have been working on today!
Old 04-08-2022, 07:47 PM
They are thin. You can see the right side needed some help when Paul had it. I fear if I lay a welder to it, I'll just blow through it. Paul and I both wanted to try to hang on to what's left of the original pipes. At some point they will require a proper burial.
Old 04-08-2022, 09:12 PM
Unanimous, the TT's look much better with the color.
You will blow thru on the pinhole. I start at least an 1/8th inch outside with reduced heat and quite a bit more wire speed. Short, tack welds until you find good enough metal to weld to. Once you have a solid perimeter, you weld to that and close up the hole. Careful grinding to flush and a spray of salt water on the bare metal will blend it some.
If you have a Dent Fix Eliminator, with the medium wire wheel, will make a close replication of metal texture to hide the grinder marks. I always finish grind with 120 too.
big gear head (04-09-2022), napa68 (04-09-2022)
  #220
Old 04-09-2022, 03:30 PM
----Bill,,,I'm a certified Seville slappy having owned 3 of them so far. If I had the garage space I'd be giving someone (Tim) with what appears to be a pristine yellow one a call! They are such a cool design and size. Very appropriate "go to dinner" with another couple car.....Bill S
67since67 (04-11-2022), napa68 (04-09-2022)
