Old 04-20-2022, 11:21 AM
dykstra's Avatar
dykstra dykstra is offline
Looks and sounds great Jake!! Now it runs as good as it looks!
Dave Dykstra
NCRS#66003
you. – Jeremy Clarkson.
Dykstra Motorsports
RPOLS3 (04-20-2022)
  #132
Old 04-20-2022, 01:08 PM
Wow !! The pics at the airport are way cool !! The car looks great...
RPOLS3 (04-20-2022)
  #133
Old 04-20-2022, 02:59 PM
----You have it nailed, Jake! The wheels, the drivetrain, the lack of an SS hood (which I love). A beautiful semi-sleeper. It's so cool that you resisted the trmptation to slap a hood on your ride. So many others have it's rediculous. There are probably 6-cylinder Chevelles running aound with SS hoods.....Bill S
67since67 (04-20-2022), RPOLS3 (04-20-2022)
  #134
Old 04-26-2022, 05:49 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
As I just posted in the thread about replacement washer pumps, I ordered a replacement windshield washer pump assembly from Ground Up and will take my time rebuilding the original to avoid further down time. This past Sunday I replaced the spark plugs for the first time in 20 years. Today I purchased a new NAPA RR165 distributor cap (black with the copper terminals and still made is USA) along with a new rotor.
Jake Dykstra
Dykstra Motorsports
The Following 3 Users Say Thank You to RPOLS3 For This Useful Post:
dykstra (04-27-2022), napa68 (04-26-2022), olredalert (04-26-2022)
  #135
Old 05-03-2022, 01:42 AM
RPOLS3's Avatar
My reproduction washer pump arrived over the weekend - so I swapped it out this evening. Not a bad repro part - does not have the Delco Remy stamp on the bottom of the stamped steel base and the plastic cover is slightly different. I was able to swap the original cover on the repro unit for now.
https://youtu.be/DrF1zx8_3_4
Also swapped out a throttle return spring to hopefully cure an issue with not returning to normal idle (weak spring). Slowly but surely getting things dialed in.
Jake Dykstra
Dykstra Motorsports
1972convss454 (05-03-2022), dykstra (05-03-2022), olredalert (11-30-2023)
  #136
Old 05-03-2022, 11:49 PM
RPOLS3's Avatar
FYI on wiper blade inserts for these old cars which are getting harder to source.......NAPA carries a "classic" replacement line. This line includes an assembly with the rubber insert already installed on an arm blade that sorta-kinda looks correct - from far away. Not going to pass any judging, but fine for a generic replacement if you need the whole assembly. I bought a set and just removed the insert and then re-installed the rubber insert on my original arm blades. They are only $10 each. Maybe other solutions out there - doing a quick Google search of the reproduction parts houses for 16" 72 Chevelle wiper blades yields results for a reproduction assembly from Ground Up for $17 each plus shipping which usually runs $25. This was quick, easy, relatively inexpensive and looks great.
Jake Dykstra
Dykstra Motorsports
The Following 5 Users Say Thank You to RPOLS3 For This Useful Post:
1972convss454 (05-04-2022), dykstra (05-04-2022), mhurd (05-04-2022), Mr70 (05-04-2022), olredalert (06-20-2022)
  #137
Old 06-20-2022, 02:06 PM
RPOLS3's Avatar
Finally put some miles on the Chevelle this weekend. Given all of the new replacement/rebuilt parts I wanted to slowly extend the miles away from home before I committed to a longer trip. I've primarily been doing a 5 mile loop around the area I live for testing and have had no issues. Last week I took it to a cruise night locally which was about 10 miles round trip (that's when I found the A/C issue). On Friday the wife and I took a longer run up to Clinton, WI for dinner - about a 50 mile round trip with no issues. With that under our belt we drove it down to my parent's on Saturday for Father's Day which is about 120 miles round trip. Ran great with no issues - so I think we're good. Nice to enjoy as it was intended.
Jake Dykstra
Dykstra Motorsports
The Following 8 Users Say Thank You to RPOLS3 For This Useful Post:
1972convss454 (06-20-2022), big gear head (06-21-2022), dykstra (06-21-2022), napa68 (06-21-2022), olredalert (06-20-2022), orig69ss (06-22-2022), scuncio (06-20-2022), Xplantdad (06-20-2022)
  #138
Old 06-20-2022, 03:17 PM
1972convss454 1972convss454 is offline
Awesome!
Joseph Farrow
1970 Chevelle L78
1970 Chevelle LS6
1972 Chevelle LS5
The Following User Says Thank You to 1972convss454 For This Useful Post:
RPOLS3 (06-20-2022)
  #139
Old 11-23-2022, 01:58 AM
RPOLS3's Avatar
So.....the bench seat had developed some wear and tear(s) over the years and with the cruising season over here for the year I decided to look at fixing it. There was one significant tear at a pleat/panel joint and it was getting worse as I drove the car this summer. In addition I could see where there were 4-5 other spots on the seat bottom that were starting to come apart as well. I really did not want to buy a reproduction seat cover as most of the original seat cover was still in pretty good shape (or so I thought). I found a local upholstery shop and he was knowledgeable enough about buying the NOS material from SMS as he had previous experience in doing so. He pointed out to me the the drivers side of the seat cover had already been repaired with a close but non matching material (I've owned the car since 1987 - so it was a while back) He ordered the NOS material from SMS and got it in a couple of weeks. I dropped of the seat about a month ago and picked it up today. He replaced the bottom main (pleated) areas on both sides and the drivers seat back (pleated area) with the SMS materials. I was pleased to be able to save the original seat cover and use the SMS material to retain the correct original appearance as the car retains its born with carpet, all door panels, and rear seat.
I also installed the NOS radio knobs I picked up from Rick at MCACN this past weekend. Winter project already completed.
Jake Dykstra
Dykstra Motorsports
69M22Z (11-23-2022), big gear head (11-23-2022), dykstra (11-23-2022), L78_Nova (11-23-2022), L_e_e (11-23-2022), napa68 (11-23-2022), olredalert (11-23-2022), Xplantdad (11-23-2022)
  #140
Old 11-23-2022, 04:48 AM
67since67's Avatar
Well Done, I love the floor mats!!
The Following 2 Users Say Thank You to 67since67 For This Useful Post:
dykstra (11-23-2022), RPOLS3 (11-23-2022)
