Old 05-30-2022, 12:37 AM
JRC99's Avatar
JRC99 JRC99 is offline
Originally Posted by Too Many Projects View Post
Sounds like a cam lobe going flat, usually the exhaust letting the burned fuel back fire thru the carb.
That's what I was afraid of.
The good news is that I'm living at Pappaw's house now, and there's an iron beam with a chain for engine pulling (since if I'm going this far into it, I may as well pull it and have everything inspected)
The bad news is that the car is at Mom and Dad's. I'll pull the over valve cover tomorrow and have a look I guess.
Not surprising, but still a bummer.
My cars, passed down by my grandfather:
'68 Camaro SS (454/TH400, possible L78/M22) LeMans Blue, black deluxe interior, black vinyl top. 3.73- mostly Day 2.
'89 Mustang GT- 3.55, subframe connectors, muffler delete, and a couple other minor mods. Exactly as he wanted it, so how it shall stay
Also:
1995 Ford F-150 XL
2004 Dodge Ram Hemi GTX- #192 of 433
Ain't no fun in viewing your car as an 'investment'. Get out there and beat on it!
Old 05-30-2022, 12:53 AM
Don't be yanking it out until you know what the issue is. It's much easier to do running checks with it installed than on a stand.
Old 05-30-2022, 01:04 AM
AnthonyS's Avatar
AnthonyS AnthonyS is offline
^ that.
Also, sorry to learn of your loss too man.
Anthony
Old 05-30-2022, 04:06 AM
JRC99's Avatar
I meant if it does end up being a dead cam lobe, then it's getting pulled.
Also:
1995 Ford F-150 XL
Old 05-30-2022, 02:00 PM
Old 05-30-2022, 06:07 PM
JRC99's Avatar
Pulled the left valve cover. Everything over there looks fine.
Also:
1995 Ford F-150 XL
Old 05-30-2022, 08:01 PM
OK, assuming it isn't a flat lobe, are the plug wires on correctly ? Many people get #5 and 7 crossed when all the wires are off at the same time. On that line of thought, are the plug wires all good ? Old, cracked wires can transfer to another and cause a misfire also.
Old 05-30-2022, 08:23 PM
JRC99's Avatar
Wires are new, the noise is from the passenger side. Plus, like I said, the last rocker on #8 (I'm not sure which side is intake or exhaust but I know it's the number 8 cylinder) doesn't move much while it's running, and when I checked the lifter with the rocker off, the pop was consistent with that lobe. I did check the firing order, it's correct. Unfortunately, that pretty well narrows it down. Good thing the garage at Pappaw's has a furnace because this sounds like a winter project!
Also:
1995 Ford F-150 XL
Old 05-31-2022, 11:31 AM
dykstra's Avatar
dykstra dykstra is online now
Your intake rocker/valve will be by your intake port and your exhaust rocker/valve will be by your exhaust port. Hope this helps.
Dave Dykstra
NCRS#66003
you. – Jeremy Clarkson.
Dykstra Motorsports
JRC99 (05-31-2022)
  #260
Old 05-31-2022, 03:06 PM
JRC99's Avatar
Ah, right! It's the exhaust valve on #8 then!
Also:
1995 Ford F-150 XL
