Old 07-10-2022, 11:29 PM
jbtech's Avatar
jbtech jbtech is offline
Originally Posted by R68GTO View Post
Job well done Jose. Very cool to document this process, thank you!
Thank You!
Carefully scraping away the spray bomb I believe I found the missing 3rd ink stamp on the RH side. Remnants of the ink stamp appear to have stuck to the white "O". When comparing the other stamps the orange is the same color.
I also carefully scraped away the spray bomb surrounding the tag. I'm hesitant to use a reducer here but luckily the manual method seems to be working for now.
A lot more work to do! Shout out to Darrell and James for the inspiration to do this type of work.
Jose Betancourt
67 Camaro L78
The Following 7 Users Say Thank You to jbtech For This Useful Post:
69M22Z (07-11-2022), big gear head (07-11-2022), dykstra (07-13-2022), juliosz (07-24-2023), PeteLeathersac (07-11-2022), SuperNovaSS (07-11-2022), Too Many Projects (07-11-2022)
  #132
Old 07-11-2022, 01:55 AM
Lots of dirty work in a restoration/preservation job. I always dread this and it's hard to get started, but once I do, I'm OK. I usually end up looking like the car used to by the end of the day...
Old 07-12-2022, 05:04 AM
jbtech's Avatar
Slowly chipping away. Here's progress around the heater cutout and cleaned up the tag a bit. My eyes need a break.
Jose Betancourt
67 Camaro L78
The Following 2 Users Say Thank You to jbtech For This Useful Post:
big gear head (07-12-2022), dykstra (07-13-2022)
  #134
Old 07-12-2022, 06:55 AM
Denis Denis is offline
Pretty sure that's a "L78" and "102" markings...
The Following 11 Users Say Thank You to Denis For This Useful Post:
67 Nova Boy (07-15-2022), big gear head (07-12-2022), dykstra (06-23-2023), Hawkeye (07-12-2022), jbtech (07-13-2022), juliosz (07-24-2023), olredalert (07-12-2022), RobR (07-12-2022), SuperNovaSS (07-12-2022), Xplantdad (07-12-2022), YenkoYS-199Stinger (07-12-2022)
  #135
Old 07-13-2022, 01:47 AM
jbtech's Avatar
Denis that seems to be the consensus. Once seen it can't be unseen lol.
I'm told the 102 means it was the 102nd car in the line that day which corroborates with the orange PBT stamps as it was early in the 1st shift.
I'm also being told that this was sometimes found in the lower valence. Well here is my lower valence. (Image flipped for easy reading). I now need to confirm that the lower valence is original to the car.
Jose Betancourt
67 Camaro L78
big gear head (07-13-2022), dykstra (06-23-2023)
  #136
Old 07-13-2022, 06:11 AM
jbtech's Avatar
I've discovered "1 02" also on the lower front valance!
Jose Betancourt
67 Camaro L78
The Following 4 Users Say Thank You to jbtech For This Useful Post:
67 Nova Boy (07-15-2022), big gear head (07-13-2022), dykstra (07-13-2022), Xplantdad (07-13-2022)
  #137
Old 07-13-2022, 06:24 AM
jbtech's Avatar
Here is a photo with all the numbers wet showing the white numbers more pronounced. Does anyone know what the other 2 numbers/characters mean?
Jose Betancourt
67 Camaro L78
The Following User Says Thank You to jbtech For This Useful Post:
  #138
Old 07-13-2022, 11:00 AM
R68GTO R68GTO is offline
Is the 102 the assembly sequence number?
Old 07-15-2022, 05:26 AM
jbtech's Avatar
That's what I've been told. And there is evidence that contributes to this. My car has orange stamps which indicates 1st shift and the 102nd car would certainly be built during first shift. There is another "survivor" car with a number over 500 in the lower valance and the PBT stamps are green, thus the car was completed during 2nd shift. I think it would be cool to gather enough data points regarding possible sequence number and color of PBT stamps to prove this theory once and for all.
Jose Betancourt
67 Camaro L78
Old 07-18-2022, 05:40 AM
jbtech's Avatar
After more chipping I decided to give the gel evaporust a shot on the firewall. Still need to clean it up and hit it again.
I avoided the 102 mark and the center of the firewall as I still need to figure out the marks in that area behind the distributor.
I plan to use a multi color flashlight to help reveal what the markings are in the dark. Up close I see multiple X's but when the flashlight gets here I'll see if I can get those marks to reveal themselves.
In the meantime here is a progression shot. Still a ways to go.
Jose Betancourt
67 Camaro L78
The Following 6 Users Say Thank You to jbtech For This Useful Post:
big gear head (07-18-2022), dykstra (06-23-2023), juliosz (07-24-2023), olredalert (07-18-2022), Steve Shauger (07-19-2022), SuperNovaSS (07-18-2022)
Tags
1967, 396 ss, l78 camaro
