Old 09-17-2022, 12:28 AM
scuncio scuncio is offline
Originally Posted by Pro Stock John View Post
Hmmm are they polished?
No, they are satin.
Old 09-17-2022, 02:44 PM
Pro Stock John's Avatar
Thx I'd nerd out for some polished skinnies. I wonder if those could be polished.
Old 09-17-2022, 02:45 PM
Originally Posted by chevyman0429 View Post
Iv got a set of 15x10 super tricks that are polished that I would sell or trade for a set that isn’t polished !
Thx but won't fit my car. I'm runnin 15x12 1.5 backspace wheels in back.
Old 09-19-2022, 07:03 PM
For sure, I think that would be straightforward if you removed the through-bolts.
Old 09-21-2022, 05:50 PM
Thanks but Imma hold off.
If nobody gets serious on buying these Cragars I'll look for some front tires and swap 'em on and see how they look.
Old 10-01-2022, 12:41 PM
DW31S's Avatar
DW31S DW31S is offline
Couple things…
Name that car “Rowdy from Dowdy”!
As for polishing satin Super Tricks, I’ve done them and figured out what and what does not work. First of all, they need to be separated and all hardware removed. Before you split the fronts/backs mark them and the center lug hole plates so they go back together as originally constructed. Once they’re apart, clean all factory sealant. Then liberally coat the front half with Easy Off oven cleaner and let it sit in the sun (if possible) for 15-20 minutes. Hose down/wipe clean and then repeat. Once ALL the clear anodizing is removed then you can start polishing. Basically, polish them as you would wet sand buff paint. I usually start with 600 and finish with 2.000. Then buff a couple times with Mother’s. Lastly, I do a final coat by hand with Diamond metal polish/sealant. Once the polishing is to your liking, reassembly is next. I always use clear silicone on the lug plate rings where they meet the wheel disc and then install new hardware (which I have if anyone needs it). Once they’re back together, run a nice bead of silicone around the joint where the front/back parts of the wheel meet. I let this sit for a day, and then lay another bead over that one (a little wider) and then let that sit for a day. Finally, they are done. This procedure is a royal pain in the ass, but it works. I’ve never needed tubes in front or rears after this process.
The Following User Says Thank You to DW31S For This Useful Post:
RobR (10-01-2022)
  #37
Old 10-01-2022, 06:40 PM
Thanks for info. I bought a set of Cragar SST, chrome I would say, back in 1991. I really liked those.
Old 12-07-2022, 10:12 PM
Had a good season with my modern day 2 lol...
Next season I'll slap on a fresh set of tires in back and hit GLD. I'd like to run 8's with the current mill.
The new engine is an LC9 will be all forged including the crank and I'll also be using a set of TFS as cast 220s. I might swap a 91mm turbo on it too that will eventually happen. With this new engine I'll be looking to run 7.90s in a cruisable car.
The Following 6 Users Say Thank You to Pro Stock John For This Useful Post:
dykstra (12-08-2022), L78_Nova (12-08-2022), napa68 (12-08-2022), olredalert (12-08-2022), Tenney (12-08-2022), Xplantdad (12-07-2022)
  #39
Old 12-07-2022, 10:56 PM
Very cool!
Old 12-08-2022, 12:23 AM
Crush Crush is offline
7.90 s!!!!! Wow that would be crazy fun on the street. Let’s hear a video of it running!
The Following User Says Thank You to Crush For This Useful Post:
