Old 10-07-2022, 02:24 PM
Zman1969 Zman1969 is offline
Default 69 small block mount info
wondering if this was a production mount or when in production it started? I've never seen these in person - also any info on the bolt and spacer would be appreciated
69 RS/Z 302 VE3 Daytona
69 Chevelle SS 396 375
69 T/A clone LS6/6 speed
90 Formula 350
Attachments - The Supercar Registry eng mount 3.JPG assembly manual (2).jpg 69 Z28 motor mounts original.JPG 69 sbc mount.jpg
Old 10-07-2022, 02:58 PM
X66 714's Avatar
X66 714 X66 714 is offline
That bracket is on upc Z28, sheet A4 in the AIM. It looks like it was drawn 8/2/1969. My 8/28/1969 had that same system even though it's a 396. Mounting bolts to the block are a thread or so longer on the driver side...Joe
Old 10-07-2022, 07:16 PM
THX X66 I saw that Heartbeat offers repro brackets for SB and BB but not the correct mounts, the longer mount bolts is understandable but I was curious about the long through bolt and spacer, washers any chance you can post some pics up? I'd love if anyone has dimensions available of spacer - length of through bolt OD of washer and thickness ect
I'm also going to look back through the legends manual
90 Formula 350
Old 10-07-2022, 09:59 PM
X66 714's Avatar
I cheated a little because I didn't want to spend 1,500.00 plus on original mounts. A copo, i would've. You have to put a bevel on one edge of the mount where it meets that bracket. I got the bolt from Rich who used to sell hdw here. I might have to take mine out to replace a freeze plug. Here's a picture of that I did. Real pieces are hard to find...Joe
L_e_e (10-10-2022)
Old 10-10-2022, 01:00 PM
X66 that's good stuff is it in the car now? I get you on the $1500 mount thing. I have seen Rich selling on FB he even has his own page for this stuff but most is Corvette stuff I'll look through my junk first and see what I may have rat holed
90 Formula 350
Old 10-10-2022, 01:46 PM
X66 714's Avatar
That's in my car now, yes. I was comparing hdw between small block & big block. It seems to me that all the pieces were different. I'll have to go back & look. I also remember looking for the part numbers in AMK before I contacted Rich. I'll see if I can do some digging for sizes of hdw. I'm reaally surprised that somebody else hasn't chimed in about this system. If Warren was still with us (RIP), he would've been all over this....Joe
BTW, I have a repop of that bracket for a small block if you need it. HBC sent it by mistake & didn't want it returned
Old 10-10-2022, 02:39 PM
rszmjt rszmjt is offline
There is a post on CRG i was involved in regarding the original production mounts. Here is a picture of a original set of Z28 mounts i have, lift plate is a reproduction.
The Following 3 Users Say Thank You to rszmjt For This Useful Post:
enio45 (10-12-2022), mhm1966 (10-10-2022), X66 714 (10-10-2022)
Old 10-12-2022, 02:32 PM
Thanks but these came with both mounts and brackets and some hardware was missing due to poor packing I have contacted Rich and he will be digging me up some hardware
cool and I forgot to look on CRG -older age is great isn't it? -I found the thread there, was hoping for some measurements of through bolt spacer and washer if its handy? I have also reached out to Lloyd Edgemont as he was looking I'm pretty sure he has located it by now
90 Formula 350
The Following User Says Thank You to Zman1969 For This Useful Post:
X66 714 (10-12-2022)
Old 10-13-2022, 01:01 AM
I will try to dig it out on the weekend and get the measurments.
The Following User Says Thank You to rszmjt For This Useful Post:
Zman1969 (10-13-2022)
Old 10-13-2022, 09:12 PM
Edgemontvillage's Avatar
"Cool and I forgot to look on CRG -older age is great isn't it? -I found the thread there, was hoping for some measurements of through bolt spacer and washer if its handy? I have also reached out to Lloyd Edgemont as he was looking I'm pretty sure he has located it by now[/QUOTE]"
Mike (rszmjt) is your best source for the measurements on those second design mounts as I have the first design (and they're now installed on the car).
Lloyd.
The Following User Says Thank You to Edgemontvillage For This Useful Post:
mhm1966 (10-14-2022)
