Old 12-04-2022, 02:19 AM
iluv69s iluv69s is offline
Default Nickel in blocks???
Saw this on FB.. varying replies as if it is an urban legend.
Anyone know the real deal?
Attachments - The Supercar Registry Top of timing chain comparison.jpg Timing chain comparison.jpg Oil Filter Area.jpg Main Cap Comparison 010.jpg
Old 12-04-2022, 02:27 AM
William William is offline
One of the CRG Core members asked the same question years ago. The late John Z's response:
NOPE.
"Most people have no clue how a high-volume foundry operates - the "recipe" for the grey iron and malleable iron melt load wasn't changed; it was very carefully arrived at over the years, and its content was stabilized. The "high-nickel block" theory was debunked years ago, although some folks still cling to it."
John
The Following 3 Users Say Thank You to William For This Useful Post:
dustinm (12-04-2022), L16pilot (12-04-2022), McCune (12-04-2022)
Old 12-04-2022, 03:13 AM
Very interesting, I've always heard about the 010 block being high nickel too.
So, does anyone know what the 010, 020 509 indicate on a block ?
Old 12-04-2022, 04:37 AM
cheveslakr cheveslakr is online now
Last three digits of the part number, the block applies to 3 variants on this one.
Old 12-04-2022, 01:11 PM
70 copo 70 copo is offline
Well this can be tested. Get a 307 casting and drill into it and you will see how soft the casting is compared to the same year 010 302/350.
Start there.
Casting numbers are different due to changes in metallurgical content and design.
Old 12-04-2022, 01:13 PM
69 Post Sedan's Avatar
This makes sense…..and what I assumed for years.
3970010
3970020
3951509
Kurt
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 12-04-2022, 01:18 PM
Yep. and why the need for variants??
Old 12-04-2022, 01:21 PM
Nearly all 010 castings from the mid 1970's onward were all "010" for all HP designations. Why were there basically no variants after hi compression was dropped?
MarcDant's Avatar
MarcDant MarcDant is offline
Better yet just have a metal composition analysis preformed, it will tell you all you need to know about the high nickel block, after all they did cast the harder ductile main bearing caps. So the material was there.my .002 cents.
Old 12-04-2022, 01:53 PM
Recall all those kids that did budget builds on 307's by overhauling them with higher compression pistons?
Neither do I.
