Old 12-17-2022, 11:53 PM
turbo69bird's Avatar
turbo69bird turbo69bird is offline
A freind and I were just discussing this the other day. Would appear on this car the black was sprayed after , coating the ends of the exhaust when hap hazardous eating from behind? As per the assembly manual the area around the brake drum ti backing plate is not supposed to get any paint in it so they stopped around the bolt in flange . Axles ends should be free of paint. This is my understanding anyway
The Following User Says Thank You to turbo69bird For This Useful Post:
69M22Z (12-17-2022)
  #12
Old 12-18-2022, 12:06 AM
Top is an unrestored 69 bird
Next two the low low 9k mileage camaro recently on this site,
Last on was an assembly line photo from
CRG.
Don’t necessarily match up w that red bird assembly line photo.
The Following 2 Users Say Thank You to turbo69bird For This Useful Post:
69M22Z (12-18-2022), olredalert (12-18-2022)
  #13
Old 12-18-2022, 12:16 AM
Some other pictures I had in files
This was the blue 69 vert bird much as described which is how I’d have done it at one time myself. It’s a nice clean look but maybe not correct. I also like to see the welds made to look like a welded/ heated color if it’s supposed to look like natural steel, Looks really good but again maybe not correct.
69M22Z (12-18-2022)
  #14
Old 12-18-2022, 12:24 AM
William William is offline
That's correct for a Firebird, not a Camaro.
Camaro axles, backing plates and drums were painted by the axle plant. There are several other vintage road test pics that show this.
The Following 2 Users Say Thank You to William For This Useful Post:
  #15
Old 12-18-2022, 03:50 AM
Painted separately or as a unit?
Top pic is unrestored bird has black backing plates all the way out where the red one has unpainted but over sprayed backing plates. Assembly manual shows that joint from backing plate to drum should be clear of paint and over spray . But that unrestored bird rear looks an awful lot like how the Camaro diff looks . Differnt plants? Maybe I could look at date and plant of that particular unrestored firebird
Lordstown 11C
Old 12-18-2022, 04:35 AM
And yes this is 69 bird assembly manual .if anyone has camaro please post it.
69M22Z (12-18-2022), MarcDant (12-18-2022)
  #17
Old 12-18-2022, 06:25 AM
SS427's Avatar
SS427 SS427 is offline
Probably.
Chevy axles came from the gear and axle plant. Far as I know, all were painted.
I cannot speak for F bodies but some of the A body plants received differentials that were not painted. I commonly see Baltimore, Arlington and Atlanta cars that are all natural and have a fairly large database showing this.
Rick Nelson
The Following 3 Users Say Thank You to SS427 For This Useful Post:
69M22Z (12-18-2022), Keith Seymore (12-18-2022), olredalert (12-18-2022)
  #18
Old 12-18-2022, 11:39 AM
70 copo 70 copo is offline
Lordstown 11C
Good... You are on the right track.
Old 12-18-2022, 02:10 PM
Keith Seymore's Avatar
This is a very important point.
The amount of coverage is going to vary by final assembly location (to a large degree) and by the individual operator (by a lesser degree).
K
'63 LeMans Convertible
'63 Grand Prix
The Following 2 Users Say Thank You to Keith Seymore For This Useful Post:
69M22Z (12-18-2022), SS427 (12-18-2022)
  #20
Old 12-18-2022, 02:11 PM
There was a small paint booth before body drop where the completed chassis received a spattering of "chassis black".
The chassis black was a really thin, watery "paint" that was drizzled in the general direction of the chassis as it went by. The operator shot from above, so the top outboard surfaces received the most paint, with the bottom surfaces and inboard surfaces generally missing out because that would take too much effort to bend over or reach around 500 times per day.
(Oldsmobile in Lansing plant, shown as an example)
'63 Grand Prix
