Old 01-03-2023, 10:52 PM
earntaz earntaz is offline
Originally Posted by WILMASBOYL78 View Post
I have used the GM BB hydraulic roller 502/502 cam in the 454 HO motor...it runs good and makes decent power. Pretty sure we had to use a specific distributor gear??? Aluminum heads with bigger valves and we have an Edelbrock Performer RPM, 750 or 800 Holley, TH400 with ATI convertor.
Hope that helps...
As mentioned, Eric is a good guy to run these deals by...he can help!!
-wilma
Wilma - was that the 12366543 or 24502611? Thanks ... Craig
Old 01-06-2023, 03:11 PM
Thanks Wilma ... I'm sure I will need to use a thrust plate instead of the cam button. My block is already drilled and has 1/4" tapped holes on the front of block next to the cam. What roller lifters did you use? ... Craig
Old 01-06-2023, 06:03 PM
WILMASBOYL78's Avatar
Post Camshaft...
We used the 502/502 cam...#543
Not sure about the lifters, most likely used the stock units that came with the 454HO motor. I do recall we added Eddy aluminum heads...couldn't get the small chamber [100cc] ones, so we milled the larger ones to help raise the compression...this required special pushrods.
Overall the motor runs and sounds great...pretty good power for what it is.
-wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
The Following User Says Thank You to WILMASBOYL78 For This Useful Post:
earntaz (01-06-2023)
Old 01-16-2023, 08:38 PM
VintageMusclecar's Avatar
Tom, Lynn, thanks for the plug.
I can help with either a shelf or a custom grind camshaft if you're still looking. My contact info is in my profile.
Eric
