Old 01-18-2023, 02:04 PM
Andy Andy is offline
Default 1967 Camaro Center Dash Panel Question
I've had my 67 Camaro for 25 years now and as a teenager, I made the mistake of cutting the dash and putting an aftermarket stereo in it. I was searching hemmings today and came across a 67 Camaro that was an all original car that had this dash panel in it. I'd like to remove my radio and replace it with a panel like this since I haven't listened to the radio in the car for the last 15 years. After some searching, I found this plate, which is a reproduction of what the factory used. How is it attached to the actual dash panel? Glued in place?
https://www.ss396.com/camaro/IRD-67F.html
Andy
1967 Camaro 406 4 speed
1969 C/10 383 5 speed
1969 D300 318 4 speed
1969 Super Bee 383 4 speed
1972 K/5 350 Turbo 350
1972 Duster 340 727
1974 'Cuda 340 4 speed
Attachments - The Supercar Registry UPC 1 B4.PNG Panel2.jpg Panel1.jpg IMG_0245.jpg
Old 01-18-2023, 02:33 PM
Been a while since I had mine off, but there should be 2 screws at the very bottom and then slide it up a little to disengage the hook strap at the top. You may need to remove the ash tray bracket too.
Old 01-18-2023, 02:35 PM
That is a really interesting pic. Base car with column shift, radio delete, but A/C and power windows... A frugal buyer in a hot southern state ?
Old 01-18-2023, 02:51 PM
----It would be a good thing to see the backside as there may be a bracket attached with a couple of screws that holds it on. There was on my 67 442!....Bill S
Andy (01-18-2023)
Old 01-18-2023, 03:11 PM
There is a plastic bracket at the top, Bill, but the top edge of the panel slides down into it.
And I'm wrong about the bottom, there are 4 screws...
Old 01-18-2023, 03:18 PM
Question
Thanks for the info! I am specifically wondering how the delete panel attaches to the actual dash panel? I've replaced the larger center panel twice actually. I learned something new about 67s today when I saw this car with the radio delete panel so it has me intrigued as to how it is fastened in place.
Andy
1972 Duster 340 727
Old 01-18-2023, 03:21 PM
Yes, it was a really unusual/interesting to see this car!
Here is a link to it.
https://www.hemmings.com/auction/196...&utm_campaign=
Andy
1972 Duster 340 727
Old 01-18-2023, 04:28 PM
I thought you were going to buy the repro face plate. The one in the pic appears to be all one panel too. But, if it is just a separate delete plate, it would have studs that go thru the stem holes with washers/fasteners on the backside.
Old 01-18-2023, 04:39 PM
WHY do people take pics of cars in a dark garage ????? Too dark and not a good angle to determine if that is a 1 piece face panel or a separate delete panel.
Old 01-18-2023, 04:42 PM
X66 714's Avatar
X66 714 X66 714 is offline
It's been a long time since I've had a radio block off plate but I seem to remember 2 large piloted washers that came in from the back side of the dash panel.....Joe
Andy (01-18-2023)
