#271
----I used the same wire for several resto's, but I cut them a bit longer so it was easier for me to direct them thru the hole. Shortened them after partially folding them and then flattened them.....Bill S
The Following User Says Thank You to olredalert For This Useful Post: | ||
L78_Nova (03-02-2023) |
#273
Hmmm... I know the mudflap and frame seal are correct but there were no remnants of the splash seals to check. I have a 68 which still has portions of the originals in place but it's away in storage.
68 Acadian SS-350 auto/AC driver 70 Nova SS-396/375HP Bench Stick 72 Nova SS-350 5sp Mini Tubbed 67 Chevelle Conv. SS-427 clone 70 Chevelle SS-454 LS-5 M-22 |
#274
I have always wanted to know the answer to this question.
#275
Your staples are backwards. Bent tab of the staples should be inside of the wheel well or engine compartment side. I have two original Novas and both have the staple tabs bent over on the inside. The bottom flap is correct.
The Following User Says Thank You to Mr.Nickey Nova For This Useful Post: | ||
L78_Nova (03-03-2023) |
#276
OK fixed those... upon closer inspection you can actually tell which direction the metal was pierced by the staple. Good to go
The Following User Says Thank You to L78_Nova For This Useful Post: | ||
big gear head (03-07-2023) |
#277
After hours of cleaning and painting... Grill assembly!
NOS filler panel, Argent Silver, low gloss. NOS hood latch... Dereck Approves !! And it's in.
The Following 9 Users Say Thank You to L78_Nova For This Useful Post: | ||
Arrowsmith (03-07-2023), big gear head (03-07-2023), cheveslakr (03-06-2023), Dave Rifkin (03-11-2023), dykstra (03-06-2023), olredalert (03-06-2023), tom406 (03-06-2023), Too Many Projects (03-07-2023), Xplantdad (03-06-2023) |
#278
Absolutely amazing restoration, but I Gotta say this,
put something over those heads... I was amazed your friend installed the engine without the valve covers, but seeing them still open to airborne dirt and dust is driving me nuts... ![]()
#279
![]() Quote:
Valve covers will be goin on shortly... did not want to take a chance scratching the Crane covers $$.
#280
Picking away at underhood wiring and further assembly
The Following 6 Users Say Thank You to L78_Nova For This Useful Post: | ||
big gear head (03-09-2023), Dave Rifkin (03-11-2023), dykstra (03-09-2023), Too Many Projects (03-10-2023), x77-69z28 (03-10-2023), Xplantdad (03-09-2023) |
Thread Tools | |
Display Modes | |
